Old May 25, 2013, 04:36 PM
kakemann is offline
Find More Posts by kakemann
Norway, Akershus, Aulifeltet
Joined Mar 2013
Help!
DJI NAZA problems after installing new landing gear
Hi,
I recently upgraded my quadcopter with a new landing gear. My quadcopter is now heavier than before.
I tried it today, but I experienced two different problems.
A. When yawing in GPS mode it drifts easily away from its position, and regains stability some seconds after yaw stop. It also seems like it doesn't hold it's GPS position as good as before. It drifts back and fourth.
B. I switched to failsafe (only auto land), it landed exactly where it should, but way too fast. The descending rate was to fast so it hit the ground too hard, and it flipped over.
All the gains are at 120%. I didn't change them after I installed the new landing gear. The voltage was at 3,4 pr cell when I flipped the switch to failsafe (voltage buzzer). I have the latest firmware 3.12.
So my questions are:
1. Will changing the vertical gain change anything with the auto landing in failsafe? (Increase for softer landings, maybe?)
2. Which parameters should i change, and in what direction for increasing stability when yawing, and holding GPS position?
3. Does anyone have a similar setup, and can share their settings? (This is a Storm FF drone - Like a upside down F-450 with 1100kv motors)
This is how it looks now:
This is how it looked before I changed landing gear:
kakemann is offline Find More Posts by kakemann
Poll Skywing scale Edge/Slick and Future Model Sbach: would you install wire landing gear? groovejet 3D Foamies 34 Dec 07, 2014 09:48 PM
Discussion Strange behaviour after installing new motors (Turnigy NTM Prop Drive 28-36 750KV) rvbcrs Multirotor Electronics 5 Apr 28, 2013 06:40 AM
Question Landing gear problem cmdl Electric Plane Talk 22 Apr 16, 2013 03:55 PM
Question How to install landing gear in this Bipe? engineMagnet Vintage & Old-Timer Designs 9 Mar 30, 2013 10:51 AM
Slow Stick Cof G problems after new Brushless Motor installation simonbryant Parkflyers 20 Jun 18, 2004 11:50 AM
