Old Jan 24, 2013, 08:09 AM
karikamiya is offline
Find More Posts by karikamiya
No flying at the Tower
karikamiya's Avatar
Canada, NT, Inuvik
Joined Jun 2010
Help!
Looking for automatic switch
I am looking for a switch that i can control physically or electrically, similar to a motorized pot.
ie i can flip the switch or the controller can flip the switch
anyone heard of such a device?
karikamiya is offline Find More Posts by karikamiya
Old Jan 24, 2013, 03:21 PM
whitecrest is offline
Find More Posts by whitecrest
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
A relay could be wired to operate manually or via circuit control.
whitecrest is offline Find More Posts by whitecrest
Old Jan 24, 2013, 03:43 PM
jakestew is offline
Find More Posts by jakestew
United States, ID
Joined Sep 2011
Here you go, the "automatic switch"...
The Most Useless Machine EVER! (0 min 19 sec)
jakestew is offline Find More Posts by jakestew
Old Jan 25, 2013, 01:52 AM
karikamiya's Avatar
Canada, NT, Inuvik
Joined Jun 2010
I thought about it, but i'd want the switch to be representative of the current position of the relay
Old Jan 25, 2013, 06:31 AM
orraman is offline
Find More Posts by orraman
Scottish Borders
Joined Mar 2006
A wee bit more information might help?
http://www.serelays.com/products.php?t=388J
orraman is offline Find More Posts by orraman
Old Jan 25, 2013, 12:57 PM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
http://www.youtube.com/watch?v=Z86V_ICUCD4
that is the funniest video ive ever seen. also the first time i actually appreciated a music track. thanks jake.
dave1993 is offline Find More Posts by dave1993
Old Jan 26, 2013, 12:53 AM
karikamiya's Avatar
Canada, NT, Inuvik
Joined Jun 2010
Imagine, when you turn on a device all the toggle switches automatically switch themselves to off, even if the switch was on
thats what i want, a switch that can move itself
Old Jan 26, 2013, 06:12 AM
orraman is offline
Scottish Borders
Joined Mar 2006
Latching relays are available with single or double coils that can be energised by a short pulse and the contacts will remain in that state until a new pulse reverses the magnetic path.
Single coil relays require the current flow to be in the reverse direction in the coil to toggle.
Double coil relays require the current to flow in the same direction but in the coil associated with the contact requirement.
When switched ON a simple microcontroller such as a Picaxe should be able to reset a number of relays to the off position and accept input from switches to energise relays to required positions where they would remain after power down.
Heavier Double Coil relays could be controlled by a Picaxe using a single transistor driver for each coil.
Because of it's low current requirement the relay in the link below should be able to be controlled directly from a Picaxe.
The link also shows the level of information that can help to give a usable answer.
Dave
http://www.electro-tech-online.com/g...ing-relay.html
Old Jan 26, 2013, 02:51 PM
jakestew is offline
United States, ID
Joined Sep 2011
I think he actually wants to mechanically move a switch to represent what the uC is doing.
It is a bad idea though. There's many problems from a design standpoint. Unless it's a design requirement (device for the blind maybe?) you should abandon the idea. There's a reason such switches aren't made. Nobody want's to fight the uC that's supposed to be doing their bidding. There's way better ways to do things than have your electronics mechanically fight with you.
Discussion DX6i - automatic timer switching by throttle stick yogi100 Radios 13 Jul 28, 2013 09:16 AM
New Product New version of modules for automatic timer switching by throttle stick for DX6i/DX7 yogi100 Radios 0 Feb 08, 2012 04:14 PM
Discussion JR PCM9XII/DSX9/X9303 - Automatic switching of timer by throttle stick yogi100 Radios 16 Oct 04, 2010 03:55 PM
Discussion Spektrum DX7 - automatic timer switching by throttle stick yogi100 Radios 3 Sep 04, 2009 04:17 PM
