Old Jan 12, 2016, 03:13 PM
krexken is online now
Find More Posts by krexken
smoke is my wattmeter
Longview, Tx
Joined May 2008
Taped a 1/2" flat washer to the tail of the fuse today and it flew much better. It simply did everything better than before. Should have my SFG's by the weekend. Need to find a better way to get the weight rearward. My Rocket 3020 motor has a bolt on prop adapter so it's much shorter than the stock one so I had to space the motor about 5/8" from the firewall for prop clearance. Evidently shoving the motor this far forward is hurting my balance.
krexken is online now Find More Posts by krexken
Old Jan 25, 2016, 08:32 AM
pherz is offline
Find More Posts by pherz
United States, CT, Stamford
Joined Mar 2011
We had a little snow here in CT this past weekend. So, I put skis on the VIsionaire and took her out for a spin:
Visionaire on Skis (1 min 3 sec)
pherz is offline Find More Posts by pherz
Old Feb 01, 2016, 02:56 AM
MaydayMayday is online now
Find More Posts by MaydayMayday
MaydayMayday's Avatar
United States, CA, Fremont
Joined Jul 2011
Took me forever to get around to it. Finally decided I needed to switch to the toolless mod after I got too lazy to take the wings off after my last flight and probably took longer to figure out how to get it into my car than it would have to take the plane apart.
Thumb Screw:
http://www.thingiverse.com/thing:957730
Servo Connector Holder:
http://www.thingiverse.com/thing:920157
* I did not design these. Credit goes to MrBlobby for the design
MaydayMayday is online now Find More Posts by MaydayMayday
Old Feb 01, 2016, 07:19 AM
GoAround is offline
Find More Posts by GoAround
Can't fly 3D for toffee ...
GoAround's Avatar
United Kingdom, Taunton
Joined Dec 2012
I really like that ^.
However, I am confused as to why there are two servo wires going into one wing. Lights?
GoAround is offline Find More Posts by GoAround
Old Feb 01, 2016, 07:20 AM
MrBlobby is offline
Find More Posts by MrBlobby
Nederland, NB, Waalwijk
Joined Sep 2006
I designed those. How are they performing?
MrBlobby is offline Find More Posts by MrBlobby
Old Feb 01, 2016, 01:03 PM
Joined Jul 2011
LEDS!
Sorry, this is on the Night Visionaire. I'm pretty sure this is the same on the VA?
Old Feb 01, 2016, 01:06 PM
Joined Jul 2011
I just installed the screws and actually glued the harness into the fuse.
But I was plugging the cables directly into the wing and that seemed to work fine.
My Blobby,
Do you know if the harness adapter will fit the standard Visionaire?
__________________
I also cut down another set of the thumb screw adapters and glues those to the screws for my Fun Cub wings.
Old Feb 02, 2016, 03:04 AM
MrBlobby is offline
Joined Sep 2006
The foam parts of both planes are the same. You will need to fill the gap on the fuselage side to make up for the missing connector for the lights. A piece of balsa will do the trick.
A tip for mounting the screws into the adapter. Heat the screw head and allow it to melt into the adapter. The plastic will flow into and around the head a bit. That will fix it in place nicely and have good grip.
Old Feb 02, 2016, 07:49 AM
pherz is offline
Joined Mar 2011
Skis on my Visionaire
A friend of mine took these shots of my Visionaire while flying with skis on Sunday
Old Feb 02, 2016, 01:53 PM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16 STILL APPLIES
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Nice!
Homemade skis?
Sammy70 is offline Find More Posts by Sammy70
Old Feb 06, 2016, 04:30 PM
Raften is offline
Find More Posts by Raften
NorCal
Joined Dec 2009
Any pictures of different motors and how they have been mounted? My motor fell out in flight most likely from aprop strike on takeoff. Just unscrewed itself and chopped the wires.
Raften is offline Find More Posts by Raften
Old Feb 07, 2016, 12:35 AM
partytimes08 is offline
Find More Posts by partytimes08
United States, MN
Joined Feb 2014
After about a year when depth perception finally got the best of me and I slammed my visionaire into the top of an oak tree I changed mine out for an eflite power 10 with 12x6 apc prop with 5085mg servos. Fits the same mount. Just used some aluminum washers to move the motor forward a bit. Flew like a brand new plane after that!
partytimes08 is offline Find More Posts by partytimes08
Discussion Parkzone's New Habu 2 EDF ChuckTseeker Foamy EDFs 4776 Feb 06, 2016 12:03 PM
For Sale New Parkzone S.E.5a w/ AR600 Rx - LPU Kevinfred Aircraft - Electric - Airplanes (FS/W) 1 Jul 12, 2012 01:26 AM
Sold New Parkzone S.E.5a w/ AR600 Rx - LPU Kevinfred Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Jun 23, 2012 10:10 AM
