Old Mar 10, 2013, 03:35 PM
hifinsword is offline
Find More Posts by hifinsword
Blue Skies
hifinsword's Avatar
United States, VA, Williamsburg
Joined May 2012
E-1003 Head and mixing arms
Originally Posted by aphex4000 View Post
Yes, it's a direct drop-in conversion as the dimensions of the head are all the same. I'm using 9116 rotors, flybar, and links.
Thanks, might as well get two for that price.
hifinsword is offline Find More Posts by hifinsword
Old Mar 10, 2013, 04:06 PM
Steve_ is offline
Find More Posts by Steve_
More Flights = Less Crashing
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Content Removed due to the fact that I do not agree with forum policy
here, and do not want them generating profit with my content.
Steve_ is offline Find More Posts by Steve_
Old Mar 10, 2013, 04:25 PM
Mdigiovabc is offline
Find More Posts by Mdigiovabc
Canada, BC, New Westminster
Joined Feb 2012
Originally Posted by Steve_ View Post
My 250 clone fixed pitch conversion is using Wasp V3 electronics and motor,
with the older Sky-703 TX, and it works perfectly.
You can use most of the 4500KV motor, my setup tops out at 75% throttle,
but I could use more power if I had the head balanced properly.
It's on my long list of projects.
Remember folks, the whole deal.... the CF frame, belt drive tail, the
super-awesome swashplate, the resilient skids, a nice looking canopy,
and a CP head (when you are ready) ....is only $35.
I understand and it makes perfect sense but I would like to change the electronics on the 9116 and keep the rest of the 9116. I already have a 450 clone to work on next but I just can't start on this until I finish tinkering with the 9116 (which might be never).
I've changed my thoughts on the brushless tail motor/belt drive. I would like to keep my Honey Bee CP3 direct drive brushed motor and use a brushed ESC. I have found one for aprrox $14 shippped. Since I won't need the head speed that the 4500kv motor provides I'm thinking of using a 3500kv motor.
Mdigiovabc is offline Find More Posts by Mdigiovabc
Old Mar 10, 2013, 05:06 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Old Mar 10, 2013, 07:13 PM
Pa flyer is offline
Find More Posts by Pa flyer
Joined Aug 2012
Mdigiovabc, I just read your previous post and checked my Wasp against the 9116 and there is no way that you would be able to use the belt drive. The 9116 frame is just too small to allow any kind of modifications to utilize the belt drive.
Actually, the tail assembly is rather flimsy and too delicate on the Wasp. It's the one thing that I don't like (other than the ugly canopy) on mine. I'm even thinking of getting a HK 250 like Steve's and transferring everything over to it.
Pa flyer is offline Find More Posts by Pa flyer
Old Mar 10, 2013, 07:25 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Old Mar 10, 2013, 08:42 PM
Dweenie is offline
Find More Posts by Dweenie
Mr. Crash and Burn
Joined Jan 2013
Steve now your making me want to get a 250 kit and switch all the parts off my 9116 onto it....
Dweenie is offline Find More Posts by Dweenie
Old Mar 10, 2013, 09:51 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Old Mar 10, 2013, 10:15 PM
Dweenie is offline
Mr. Crash and Burn
Joined Jan 2013
Wait until you see it fly.
The only 9116 parts I used was the plastic shaft, the blade grips,
balance bar, and a trimmed set of blades.
It would be a very difficult project making the 9116 electronics work
on a 250 clone, but it could be done. You would need stronger
servos than the stock 9116 units.
I have quite a few spare servos for my 450 lol...I just got a spare scorpion motor looking to get a esc...I seen a nice 250 kit on hk but, I hate to see what the shipping will cost....
Old Mar 10, 2013, 11:03 PM
Laidback_racer is offline
Find More Posts by Laidback_racer
Build the Weapon....
Australia, VIC, Berwick
Joined Jan 2013
Just to see what would happen, I decided to try the F45 battery
on the 250 conversion. This battery is a 1500mAh pack that
weighs 95 grams, the equivalent of two 9116 packs.
It was obviously a little slower, but flew fine, and incredibly
stable. Actually, it was comparable to a modded 9116.
Now imagine how your modded 9116 would perform without the
weight of the battery, and you start to get an idea of what I have
going on here
It is interesting that you can use the swash design of the HK250GT with the 45 deg flybar. When I tried that with the ZR Z101 head everything was 45 deg off. When I pushed forward it went sideways. The 5-10 deg difference in phasing between the 2 heads must be the key. Do you get very accurate direction change ie does the heli follow your controls exactly, as far as on the same axis? dead forward is dead forward without any deviation etc.
Laidback_racer is offline Find More Posts by Laidback_racer
Old Mar 10, 2013, 11:12 PM
Joined Jan 2013
More on the fitment of the "feathering shaft" after finally tuning mine to perfection. After installing a slightly tight pin I lost the edge off fast forward flight, plus their was a slight hint of TBE. After fitting the 2.5mm pin I have a firm fit but nicely loose so that there is absolutely no binding. Now the heli wants to fly into the ground on full forward controls like it did previously....awesome.
I did a 7 minute flight this morning that I videoed that will be on my blog later.
Old Mar 10, 2013, 11:47 PM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Old Mar 11, 2013, 01:53 AM
Joined Jan 2013
I was actually getting that much cyclic on my 9116 just by running the 250GT
metal linkage and Wasp "green" CNC mixing arms with a modded 9116 swashplate,
but that configuration was far too much work, and the mixing arms are way too
expensive.
Sounds like it is all working, the phasing conundrum remains illusive.
Keen to see your 9116 working with align arms, which length arms work etc.
This mornings vid posted.
Old Mar 11, 2013, 03:52 AM
Steve_ is offline
Steve_'s Avatar
Joined Nov 2012
Old Mar 11, 2013, 04:23 AM
Rajah235 is offline
Find More Posts by Rajah235
Just a 9116 flyer.
Rajah235's Avatar
Australia, NSW, Wollongong
Joined Dec 2012
I haven't had that happen yet Steve.
Checked all the solder joints?
I'm still trying to work out how to reduce the HB DD tail motor.
Trims at 120% & it still wants more left trim on the Tx.
Lbr, That looks awesome.
What happened when you "lost the tail?"
Wind gust at that height maybe?
Rajah235 is offline Find More Posts by Rajah235
Discussion New Double Horse 9116 RC Helicopter 4 Channel 2.4Ghz RTF with Gyro thercguy Electric Heli Talk 4 Apr 16, 2013 03:13 AM
Question Double horse 9116 Heli capo58 Beginner Training Area (Heli-Electric) 3954 Dec 26, 2012 07:40 AM
Discussion New to Heli's - Double Horse 9116 or 9118 kamma1124 Coaxial Helicopters 19 Sep 28, 2012 10:08 PM
Question Starting with a new Double Horse 9116 Scotticism101 Beginner Training Area (Heli-Electric) 3 May 15, 2012 01:36 PM
Discussion 9116 Double Horse Daza1964 Beginner Training Area (Heli-Electric) 1 Mar 26, 2012 09:22 AM
