Old Dec 19, 2015, 03:05 PM
ramble392 is online now
Find More Posts by ramble392
Joined Jan 2012
Originally Posted by Chuchuf View Post
You are really going out and brave the wind and cold Steve? That's dedication!!
Terry
Forecast Sunday, high of 55 with < 10 mph wind. Not that bad, but I guess I'll see when Sunday gets here.
Steve
ramble392 is online now Find More Posts by ramble392
Old Dec 19, 2015, 10:55 PM
Traian is offline
Find More Posts by Traian
Traian's Avatar
United States, GA, Roswell
Joined Mar 2008
I have a question.
I have a seagull launch T blade. The stuff in the instructions is a classic blade.
Should I use the seagull blade? Does the tip need reinforcement for the T blade?
Steve i am not sure that i will make it tomorrow.
Traian is offline Find More Posts by Traian
Old Dec 20, 2015, 04:34 AM
krikkens is offline
Find More Posts by krikkens
Joined Aug 2009
Originally Posted by Traian View Post
I have a question.
post 1, t-blade manual ;-)
krikkens is offline Find More Posts by krikkens
Old Dec 22, 2015, 08:50 PM
GaryO is online now
Find More Posts by GaryO
United States, AZ, Arizona City
Joined Sep 2001
I have an urge to assemble the fuse without the plywood servo tray. So I could use a slightly larger battery. I'd use a cf rod to hold the lid on.
Is the servo tray needed to reinforce the nose, or for convenience in mounting the servos, or both?
GaryO is online now Find More Posts by GaryO
Old Dec 22, 2015, 09:25 PM
Roy_N is offline
Find More Posts by Roy_N
Roy_N's Avatar
United States, WA, Burien
Joined May 2014
Gary - The hatch cover is too flat for a CF rod to hold it in place. As for the servo tray, I couldn't get the tray through the hatch opening on my Helios 2X, same fuselage, so I used servo rails. Even after lawn darting this DLG several times, there aren't any signs of failure around the hatch opening. I did break the boom a few inches forward of the stab pylon.
Roy_N is offline Find More Posts by Roy_N
Old Dec 24, 2015, 02:21 AM
JONBOYLEMON is offline
Find More Posts by JONBOYLEMON
Full disclosure, not sponsored
JONBOYLEMON's Avatar
United States, UT, American Fork
Joined May 2002
The tray also helps it balance at proper cg.
JONBOYLEMON is offline Find More Posts by JONBOYLEMON
