Old Sep 26, 2011, 07:55 PM
scharlach is offline
Find More Posts by scharlach
Joined Jan 2005
3.2 gm Micro Airplane / Flies great!!
After a lot of trial and error I have come up with a Super Micro Airplane
that flies great Indoors or outdoors (with near calm wind).
I took it over to local flying field today for tests in larger area than
my small back yard. It flies very good with flight time in 4 to 5 min
range. Here are the details:
Wing: Span 6", Cord 1.5" Made from 0.5 mm CF rod, 1 mm Depron ribs,
saran wrap covering
Horz Stab: 2.25" x 0.7" Made from 0.5 mm CF rod & 0.67 mm Depron
Vert Stab: 0.7" wide x 1" high Made from 0.67 mm Depron
Rudder: 0.4" wide x 0.9" high Made from 0.67 mm Depron
Fuselage: 4.5" long Made from 0.5 mm CF rod
Motor: 4 x 11 mm, 13 ohm coreless
Propeller: Plantraco 32 mm
Receiver:
1. Plantraco Butterfly 2Ch, 0.38 gm Actuator Receiver for those who have
Plantraco 900 mhz transmitter
2. Deltang RX43 4 ch, 0.35 gm Actuator Receiver for those who have
DSM2 Spektrum or JR transmitters.
Actuator: Plantraco Nano Actuator 0.07 gm
If there is a lot of interest let me know and I will try and get a video made!
Parts Available from the following sources:
BSDMicroRC.com, Plantraco.com, Micronradiocontrol.com
Battery: Full River 1S/20mah
scharlach is offline Find More Posts by scharlach
Old Sep 27, 2011, 08:54 AM
Brent Slensker is offline
Find More Posts by Brent Slensker
Weni, wedi, Java...
Brent Slensker's Avatar
Casper, Wyoming
Joined Nov 2009
I'd like to see a video!!!!...I have all that gear, I just have not built that small yet
Brent Slensker is offline Find More Posts by Brent Slensker
Old Oct 01, 2011, 02:12 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
I second Brent.
boredom.is.me is offline Find More Posts by boredom.is.me
Found Aluminum 30mm spinner with collet for 3.17 shaft or GM 4.75x4.75 Pylon set 3.2 shaft josephcharles Aircraft - Sailplanes (FS/W) 1 Jun 05, 2011 07:37 PM
Sold PICO SLICK 3D/Aerobatic (Receiver Ready) Airplane 21.3 gm scharlach Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Jan 24, 2011 11:30 PM
Sold KOLIBRI RTF Micro Airplane 3 CH, 5.44 gm scharlach Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Dec 24, 2010 11:51 AM
Discussion What motor/gear/prop for 2.5 to 3 gm airplane? scharlach Scratchbuilt Indoor and Micro Models 4 Jul 28, 2008 03:55 AM
Discussion Any quality 3 to 4 gm micro servos out there? snopro_440 Radios 1 May 06, 2008 03:03 AM
