Old Jun 28, 2011, 05:39 PM
rcalldaylong is offline
Find More Posts by rcalldaylong
Dude, I do fly all day long!
rcalldaylong's Avatar
San Jose, California
Joined Dec 2007
D2822/14 Brushless Outrunner 1450kv
I'm trying to build a very light P-51...but one that has decent speed (40mph-50mph range). My build will be about 490 grams AUW
Here's the plane:
http://texasrcplanes.com/epp51d.html
Here's the motor I want to put on it
http://www.hobbyking.com/hobbyking/s...dProduct=12916
Does anyone have this motor...and can you share experience- can it manage 6x4 or 7x4 and estimate thrust...
from the specs, I see it's
Model: D2822/14
Weight: 38g
Dimensions: 22 x 28
Voltage: 7.2v~11.1v 2s~3s Lipoly
Kv: 1450rpm/v
Shaft: 3.17mm Diameter
Max Watts: 160W
Suggested Propeller: 8x6(2s) 7x4.5(3s)
max watts is 160w,...so I'm thinking it will work fine...and should get me almost 1:1.5 power ratio...but I would rather hear it from rcg...we all know how HK power ratings are
my next thought would be this motor if the one above is too small on power...
http://www.hobbyking.com/hobbyking/s...dProduct=12920
but then I would have to get a bigger esc, bigger Lipo...etc.
thoughts? comments....welcomed.
thanks.
rcalldaylong is offline Find More Posts by rcalldaylong
Sold bl-2208/14 1450kv brushless motor REDUCED nitrodude71 Aircraft - Electric - Power Systems (FS/W) 11 May 15, 2011 07:03 PM
Sold Turnigy TR 35-36A 1450kv Brushless Outrunner (Eq:2814 FieldofDreamsFlyer Aircraft - Electric - Power Systems (FS/W) 1 Mar 06, 2010 07:14 PM
Sold Suppo 2208/14 1450Kv $12.00 each awayne Aircraft - Electric - Power Systems (FS/W) 4 Sep 21, 2009 10:58 AM
Question Prop choice for GAD F-5 and Suppo 2208/14 1450kv motor Kmart Power Systems 6 May 31, 2009 09:34 PM
Question Prop choice for GAD F-5 and Suppo 2208/14 1450kv motor Kmart Pusher Prop Jet Models 0 May 28, 2009 08:26 PM
