Old Oct 19, 2001, 01:01 PM
mrebman is offline
Find More Posts by mrebman
Cincinnati, Ohio USA
Joined Nov 2000
Duskstik Question on Tail Assembly Covering?
I am just about to cover the Tail assembly on my Duskstik with Reynolds Crystal Wrap (Rose Red). The instructions say to not put covering on the bottom because that is where the stick attaches. However, the stick on uses a small amount of area, do I cover the rest of the Underside or the Horricontal Stabilizer & Elevator?
mrebman is offline Find More Posts by mrebman
Old Oct 19, 2001, 01:05 PM
VWtechie is offline
Find More Posts by VWtechie
Columbia, MO USA
Joined Feb 2001
I found it easiest to cover the entire tail and then cut out the sections that need to be bare. You should be able to peel the coveing off after trimming it with a sharp x-acto blade.
VWtechie is offline Find More Posts by VWtechie
Old Oct 19, 2001, 01:28 PM
CoClimber is offline
Find More Posts by CoClimber
Mountain Models Wannabe
CoClimber's Avatar
Ithaca, NY USA
Joined Mar 2001
What Brad said. I'll need to clear up that point in the manual.
Doug
CoClimber is offline Find More Posts by CoClimber
Discussion Lubrication question on the tail shaft Trex CDE Discusman Mini Helis 15 Oct 12, 2006 03:42 PM
Question On V-tail F5b Ship??? CHRIS_00 Electric Sailplanes 25 Nov 16, 2002 11:44 AM
Question Question on HT-13 tail section airfoil e-sailpilot86 Sailplane Talk 0 Aug 21, 2002 02:29 PM
covering question on 1st r/c alka-line Beginner Training Area (Aircraft-Electric) 8 Jan 02, 2002 07:12 PM
Duskstik Question on Covering? mrebman Parkflyers 2 Oct 16, 2001 06:39 PM
