Old Mar 07, 2011, 08:43 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Yes, that's LHCP. You need to bend the elements 90 degrees and you'll have RHCP.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Mar 07, 2011, 09:20 PM
airbagit13 is offline
Find More Posts by airbagit13
Plane Destroyer / Life Enjoyer
airbagit13's Avatar
Miami, FL
Joined May 2009
Going to test mine out tomorrow, going CP on both antennas and cant wait!
Will let you guys know how it goes. I will be using a Skew Planar / Cloverleaf.
airbagit13 is offline Find More Posts by airbagit13
Old Mar 07, 2011, 11:34 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
You will be amazed at your video quality improvement. I certainly was
Old Mar 08, 2011, 02:31 AM
Devonboy is offline
Find More Posts by Devonboy
SW England
Joined Aug 2009
The way I remember which polarisation an antenna will be is by looking at single element from the outside.
It depends on which way the element 'leans' from the bottom point to the top point.
So, an element that looks like this \ is leaning to the left = Left Hand CP
and an element that looks like this / is leaning to the right = Right Hand CP
Nigel.
Devonboy is offline Find More Posts by Devonboy
Old Mar 08, 2011, 04:17 AM
Mictronics is offline
Find More Posts by Mictronics
Joined Dec 2009
Mictronics is offline Find More Posts by Mictronics
Last edited by Mictronics; Jul 02, 2012 at 01:25 AM. Reason: Tired of RCG - Quality can be found at FVLAB
Old Mar 08, 2011, 06:20 AM
Peter Seddon is offline
Find More Posts by Peter Seddon
Solihull, England
Joined Jun 2004
Soldering of connections
I am hoping to build this antenna for 2.4GHZ but am having slight problem understanding the way that it is connected to the coax feed. I can see that the two arms of the antenna are soldered at right angles at the mid point of the long sides. Is that where the screen of the coax is soldered? That leaves the four ends of the arms. Do they get soldered together with the inner of the coax?
Peter
Peter Seddon is offline Find More Posts by Peter Seddon
Old Mar 08, 2011, 06:21 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Peter - Yes, that is correct. The 4 ends get soldered to the coaxial cable cienter element, the shield gets soldered to the cross junction.
-Alex
Old Mar 08, 2011, 11:01 AM
Solihull, England
Joined Jun 2004
Thanks Alex,
Which do you recommend the pin wheel or three leaf clover?
Peter
-Alex
Old Mar 08, 2011, 11:11 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
For the TX I recommend the cloverleaf. For RX I recommend the skew-planar wheel.
Old Mar 08, 2011, 11:41 AM
airbagit13's Avatar
Miami, FL
Joined May 2009
Oops had mine backwards lol, had my Clover on the RX and vice versa. I will switch it out before I fly!
Old Mar 13, 2011, 08:58 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Nigel.
Now that's an explanation I can understand. I could never quite figure out L/H, R/H polarization until now. Thanks.
Vantasstic is offline Find More Posts by Vantasstic
Old Mar 14, 2011, 12:14 PM
crezzee is offline
Find More Posts by crezzee
Build Fly Crash Repeat
crezzee's Avatar
Worcester UK
Joined Nov 2004
Hi, I'm going to build a spw antenna for my 2.4Ghz vrx and a cl for the vtx.
I have a question regarding the intersection angle of the spw.
Originally Posted by Ibcrazy
The tip of the wire should meet the center at a ~105 degree angle. It will not (and should not) intersect at 90 degrees.
After using this online calculator:
http://www.handymath.com/cgi-bin/arc18.cgi?submit=Entry
I find the angle should be more like 114 degrees.
What angle is correct?
Am i overthinking this?
Cheers
crezz
crezzee is offline Find More Posts by crezzee
Old Mar 14, 2011, 01:10 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
You are overthinking it The point of that statement was just to keep people from trying to force a 90 degree intersection.
-Alex
Old Mar 14, 2011, 03:42 PM
flight01 is offline
Find More Posts by flight01
DODOLAND
Joined Feb 2009
Hi everyone,
IBcrazy,you are a genius.I have built and try your CL antenna on 2.5 ghz and I must say that I have never been able to get such a clear video in all directions of flying since i have started FPV 2 years ago.I have try all sorts of omnis,patch,etc(except yagi) and I have always had noise.I have used the CL antenna on both the TX and RX and up to now I have push it to 1 km with crytal clear video( need some tweaking on my Dragon Link set up before pushing further).I will post a picture of the antenna and a video asap.Thanks again for sharing your ideas with us,Continue the good job.
God Bless,
Anthony.
flight01 is offline Find More Posts by flight01
Old Mar 14, 2011, 11:12 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I'm glad to hear that
It's stories like that which push me to develop even more stuff and post it here. Helping people be successful in FPV is why I post on this forum.
Have fun!
-Alex
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 53 Feb 21, 2015 07:02 PM
Mini-HowTo DIY Ground Plane omni directional RX antenna IBCrazy FPV Talk 60 Nov 19, 2012 06:11 AM
Discussion 900 mhz circular polarized antenna? g00bd0g FPV Talk 9 Aug 21, 2012 09:54 AM
Discussion 18dbi Circular Polarized Patch ? Coyote64 FPV Talk 3 Nov 10, 2010 04:59 PM
Question Circular polarized antenna question Sov4life FPV Talk 8 Mar 05, 2010 05:00 PM
