Old Jun 21, 2010, 12:11 AM
takiss is offline
Find More Posts by takiss
Patras, Greece
Joined May 2007
Charger for 6S LiPos
Hi.
I just moved to 6S Lipos and I am looking for a charger to charge 2 packs 6S 5000mAh simultaneously. I can make cabling for parallel charging, is it better to choose high wattage or 2 ports?
Hyperion EOS Duo, Bantam Cellpro 10s or what to choose?
Thanks for helping
Takis
takiss is offline Find More Posts by takiss
Old Jun 21, 2010, 09:52 AM
Hughes500Bob is offline
Find More Posts by Hughes500Bob
Retired CFI Helicopter
Hughes500Bob's Avatar
Southeast PA
Joined Jun 2007
I lkie to get as many amps and watts as possible and distribute them the way I want it distributed. Dual pack chargers are not my style.
VOLTS x AMPS = WATTS
6S 5000 mAh at 1C charge rate is 6 x 4.2v x 5 amps = 126 watts
6S 5000 mAh at 2C is 10 amp charge rate and 252 watts
iCharger 206B is 6S, 20 amps, 300 watts
iCharger 208B is 8S, 20 amps, 350 watts
iCharger 3010 and FMA Cell Lab 8 are both 30 amp 1000 watt "capable" chargers. (Output dependent on input of power supply!)
http://www.progressiverc.com
If you wanted dual ports instead of a nice parallel charging and balancing rig ..... you need 6S and 126 watts minimum on each port of a dual port charger.
Bob
http://rcsales.shutterfly.com
Hughes500Bob is offline Find More Posts by Hughes500Bob
Old Jun 22, 2010, 05:17 AM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
Depends on your budget, your needs/wants, your power supply and what tickles your fancy
Having used both DUO-style and single-port chargers I prefer single-port. I find it confusing and error prone using a DUO-style. However if DUO-style is your preference and you are on a tight budget you could consider the new iMax B6 DUO which offers 2 x 6S, 200W/10A.
If money is less of an issue then I would go for a high-power single port charger and charge in parallel. Pick of the crop is probably the FMA PowerLab8 once they start shipping, closely followed by iCharger 206B, 208B or 3010B depending on your hunger for power.
If you are not in great hurry it might be worth waiting a couple of weeks to see what the new Hyperion SuperDUO looks like. It is specified as 2 x 7S, 500W/20A which is a big step up from the current generation DUO3 (2 x 6S,180W/15A).
If you know someone that will let you use their DUO-style charger, try it out, particularly if you think you might be charging dissimilar packs or starting/stopping charging packs at different times. See if the usability matches your expectations.
Whatever you choose, don't forget that your budget has to cover a suitable power supply with enough capacity to support charging at the maximum power level you anticipate using. For most chargers over 200W total output that implies voltages in the 15-24V range since they cannot deliver their full rated output from a 12V (or 13.8V) supply.
kgfly is offline Find More Posts by kgfly
Wanted Want To Trade DX5e For Lipo Charger/Balancer w/PS, Must Charge At Least (2) 6S Lipos RaySuave Aircraft - Electric - Batteries & Chargers (FS/W) 0 May 14, 2010 10:30 PM
Discussion Which Pair Lipos for 12s (2650 6s or 3300 6s) Bigrcfan Electric Heli Talk 5 Jan 09, 2010 10:46 PM
Help! can't decide which charger to buy for 6s lipos??? pairadocs Batteries and Chargers 13 Aug 25, 2008 08:36 PM
Wanted mulitchemistry balance charger... must charger at least 6s lipos and 8cell nimh/cd. burke757 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Apr 25, 2008 10:22 AM
Discussion Charger for 6s lipos AND 10s a123 (how about this one?) Mist-R Mosquito Batteries and Chargers 9 Mar 26, 2008 09:25 AM
