Old May 07, 2010, 11:16 AM
CrazyDocBrown is offline
Find More Posts by CrazyDocBrown
Joined May 2010
High powered servo?
I had a project I wanted to run by you guys.
I have a camera on a rig with some castors and it moves in a track. I need the whole rig to move back and forth in this track, and I need a pretty high degree of precision as to the position. So I wanted to hook up a servo/stepper motor to a push rod and have it move the thing to a position depending on the computer input.
I'm comfortable with the setup/wiring, but I was wondering if it's feasible to get this much force out a servo/stepper.
Here's the numbers:
The track will be 6-12 inches long, and the rig needs to move to any position somewhere on the track.
The rig can be a little heavy, so I'm thinking about 10-15lbs of force are needed to push it back and forth.
I don't need really high speed, but if I could get 5-10 inches per second, that would be great.
I'd like to be precise about the position, say += 1/2 inch, which is why I thought of servos.
So is this doable or is it way too much torque/power for a servo/stepper motor? And if not, anyone know where I could get a motor like this for (relatively) cheap?
Much thanks
CrazyDocBrown is offline Find More Posts by CrazyDocBrown
Old Jul 18, 2010, 10:08 PM
Gualalasmooth is offline
Find More Posts by Gualalasmooth
Joined Jul 2010
Threaded worm drive should do you fine or maybe a linear actuator will do the job
Gualalasmooth is offline Find More Posts by Gualalasmooth
Discussion Futaba S133 for aileron servo in .40 sized e-powered scale biplane insalacosm Radios 6 May 05, 2010 12:10 PM
Help! High Powered Rocket Radio? seg9585 Rocketry 5 Apr 23, 2010 04:57 PM
Idea high powered free flight 7seconds Free Flight 21 Apr 17, 2010 05:10 AM
Help! Servo Powered Quad for School. boredom.is.me Radios 7 Apr 09, 2010 10:45 PM
Discussion High powered fan test bed suggestions strictlyscale Electric Ducted Fan Jet Talk 4 Sep 13, 2009 06:26 PM
