Old Oct 10, 2006, 12:59 AM
bcc1955's Avatar
San Mateo
Joined Aug 2004
Current limits for ESCs question.
Speed control limits are always given in amperes. Does anyone know if these limits are the same regardless of voltage. In other words is it actually wattage that is more important so that an ESC can except higher current from a 2 cell lipo at 7.4 volts versus a 3 cell at 11.1 volts?
Brian
bcc1955 is offline Find More Posts by bcc1955
Old Oct 10, 2006, 03:19 AM
Letchworth, Great Britain (UK)
Joined Jul 2004
They usually also quote a voltage, or battery, range. I think the answer to your question is the both volts and amps are killers -- possibly they kill different components of the ESCs.
But, so long as you stick to the quoted voltage range, amps is all you have to worry about. Too many amps will kill your ESC irrespective of how few cells you've got in your battery pack.
abenn is offline Find More Posts by abenn
Old Oct 10, 2006, 04:16 AM
Staffs, UK
Joined Nov 2003
No it's not wattage that is important, as abenn says.
The current limit is about how much the output devices heat up and that is not really affected by the voltage they're switching.
The voltage limit is more to do with how much it takes to destroy the output devices by what is sometimes called "punch through". It's a completely different mechanism from overheating, more like the flashover you get from high voltage power lines.
Steve
slipstick is offline Find More Posts by slipstick
Question Current limits for various wire gauges? kenmalecki Electric Heli Talk 26 Jun 27, 2006 04:48 PM
Optimum current draw for Speed 300??? harvey Electric Plane Talk 1 Nov 13, 2001 03:38 PM
Input Voltage Limit for ESCs? rich hollyday Power Systems 1 Oct 24, 2001 10:45 PM
1400 AE max current? ok for T-450 Crash King Power Systems 2 Oct 22, 2001 08:33 PM
wind limits for the lite stick mattk17 Parkflyers 6 Jul 10, 2001 06:38 PM
