Old Sep 21, 2014, 09:44 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Build Log
Dynam Meteor V2 with Wemotec Minifan EVO
This is going to be my build log for the Dynam Meteor V2.
Power system:
Motor: HET 2W-27
Fan: Wemotec Minifan EVO
ESC: Hobbywing Flyfun 100 amp
I am going to be running 6S which is suppose to be around 1200 watts so this model should haul pretty good. If you are ordering the Wemotec fan from my website make sure to choose the 4mm rotor adapter as that is the size shaft on the 2W-27.
Alternate power setup for 4S (lighter as ESC is smaller and motor is lighter):
Motor: HET 2W-20
ESC: Hobbywing Flyfun 60 amp
This setup will be about 820 watts on 4S. If you are ordering the Wemotec fan from my website make sure to choose the 3.17mm rotor adapter as that is the size shaft on the 2W-20.
Now on to the build!
Don
The Don is online now Find More Posts by The Don
Old Sep 21, 2014, 09:52 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Here are some photos. I am using the inlet ring on the EVO fan to ensure the fan is feed properly on the inlet side. I used a Dremel to hog out some foam so the ring will fit. I also had to cut some foam to make the mounting tabs fit correctly. Note the back of the EVO fan is pushed rearward to meet up to the outlet. I epoxied some 1/16" plywood to be able to screw the fan unit into the fuselage. I also cut a notch in the inlet lip to allow the motor wires to puss by in the molded channel in the body. More photos to come as I get more done.
Old Sep 23, 2014, 05:17 PM
Joined Dec 2008
Interesting thread Don , I'm just now waiting for the same Meteor to show up in the mail . I too will be using the Wemo evo Mini and It'll will be powered by an Het 1w-40 with Yep 150A and 5S 3300 revolectrix . Might even experiment with 6S , after a while .Anyway subscribed , and I'll probably use a tip or two from your build . I'm going to bury some carbon arrow shaft through the model in the wings and maybe the horizontal stabs .
pencon is offline Find More Posts by pencon
Old Sep 23, 2014, 06:40 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
That sounds like some real power! I am going to add some carbon too. Just got the fan mounted. I am now debating on adding in a thrust tube as the recommended outlet is 56mm for the EVO fan and the stock outlet is much bigger.
Old Sep 23, 2014, 08:09 PM
Joined Dec 2008
I've made a thrust tube for my Vampire from .005 stainless sheet, and then before installing it in the plane , I heated it up with a propane torch so it discoloured into the blues and golds , as are usual in turkey feathers on jets . The .005 stainless is almost as light as a mylar tube would be . Only a few grams difference and much stronger and more authentic looking . This is what is going into my Meteor and also an outside stainless set of turkey feathers . The thrust tube in the pic weighs a hair over 1/2 oz so Why not ?
Old Sep 24, 2014, 12:38 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
That is cool looking with the blue temper. Never though of using that for a thrust tube!
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Here is a photo of my fan and ESC installation.
Old Sep 25, 2014, 05:17 AM
yeah
eliotek's Avatar
France, Midi-Pyrénées, Escondeaux
Joined Mar 2013
Hi guys
even if i aint got a meteor,will follow you with interest cause after several setups 1w40 wemo is the next to go in a 1500 g plane.
regards
olivier
eliotek is offline Find More Posts by eliotek
Old Sep 29, 2014, 12:20 AM
Joined Dec 2008
Yeah it's quite the killer motor ...I hope my evo rotor can take it
Old Sep 29, 2014, 12:29 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
No new info to post this weekend on this build. Was killer weather for flying this weekend. Flew 6 hours Sat, 4 hours this morning and 2 hours this evening. I will get back to the build during the evenings this week.
Old Sep 29, 2014, 01:18 AM
Joined Dec 2008
That's a nice clean install Don . I'm going to use the intake ring as well
Discussion HET 2W22 with Minifan Evo leebee1965 Electric Ducted Fan Jet Talk 5 Oct 09, 2014 01:00 AM
For Sale Wemotec Minifan EVO The Don Aircraft - Electric - Jets (FS/W) 4 Aug 09, 2014 08:30 PM
Found wemotec minifan 480 pro (70MM) 3.17 TTRotary Aircraft - Electric - Jets (FS/W) 0 Jul 24, 2014 02:07 AM
Discussion Dynam Meteor V2 with retracts Crash_Clark Foamy EDFs 1 Feb 07, 2014 07:34 AM
Sold NIB Wemotec Minifan pro 480 The Don Aircraft - Electric - Jets (FS/W) 3 Oct 31, 2013 03:39 AM
