Old Mar 24, 2014, 03:39 AM
rizky_p's Avatar
Indonesia, Jakarta Capital Region, Djakarta
Joined Apr 2007
Help!
PL8 error #96
I have been having trouble with my PL8 while my pl6 is flawless. Can anyone help with the error? PSU is meanwell SE-600-24.
rizky_p is offline Find More Posts by rizky_p
Old Mar 25, 2014, 09:45 AM
AR-15 BRD!
Howard Matos's Avatar
Frederick, MD
Joined May 2002
Hi,
The error 96 indicates the PWM ratio is too high. This error is normally associated with the power supply. Can you use a different power source and see if you get the error. You can use your car battery for a test. Let me know how you make out. You can also contact me at howard@fmadirect.com, thanks.
Howard Matos is offline Find More Posts by Howard Matos
Old Mar 26, 2014, 11:32 AM
rizky_p's Avatar
Joined Apr 2007
I'll test with 12v batteries. So why the psu is causing this error?
Discussion PL8 error 85/safety charge Jack G Diaz FMA Direct 13 Mar 16, 2014 02:24 PM
Discussion PL8 Under current, pack removed error. gmarsden FMA Direct 11 Aug 11, 2013 06:52 AM
Discussion PL8 - I keep getting these errors... 6L6Amp FMA Direct 12 Jul 10, 2012 04:25 PM
Help! new pl8 v2 - bad cell count node wiring xh error.. help? ohsnap FMA Direct 13 Apr 05, 2012 05:23 PM
Discussion PL8 CCS Pack Voltage Graphing Error Costas_ FMA Direct 5 Dec 20, 2010 09:58 PM
