Old Nov 09, 2013, 10:57 PM
Joined Apr 2013
Coordinated Turns
G'day,
Question: How does a UAV do a coordinated turn?
This is something I've been mulling over for a while, because my UAV so far just slips through turns with no rudder control at all. In a manned aircraft there is generally a turn and bank indicator or a tube in a ball somewhere. When the ball rolls away from the center point the aircraft is in a slip or a skid.
So from that I've worked out that lateral (side to side) acceleration is a symptom of an uncoordinated turn and that applying rudder deflection in the opposite direction of the acceleration will balance and coordinate the turn. Is this correct?
In straight a level flight, if there was a gust of wind for example, this would cause a lateral acceleration and consequently a rudder deflection. The rudder deflection would cause an adverse roll and change in heading, which the autopilot will try to correct for by turning . . . it seems like there might be potential for the aircraft to become unstable. I'd like to hear any thoughts about this.
Cheers, Camel
SuperCamel is offline Find More Posts by SuperCamel
Old Nov 10, 2013, 10:32 AM
Tesla's Workshop
workshop's Avatar
USA, CA, Torrance
Joined Nov 2004
On the simplistic level, mixing rudder and aileron differential to an amount appropriate to the dynamics of the subject airframe is all that is necessary to coordinate a turn and/or remove adverse yaw.
jeffparisse
workshop is offline Find More Posts by workshop
Old Nov 10, 2013, 11:28 PM
Joined Apr 2013
jeffparisse
Ahh, right. This would probably take a bit of tuning I suppose but it would certainly do the job. Thanks!
Old Nov 11, 2013, 12:13 AM
Tesla's Workshop
workshop's Avatar
USA, CA, Torrance
Joined Nov 2004
That was a trick I used with the PicoPilot that they later adapted into to their SOP... A couple of manual flights with an on-board mixer and programmable servos means one can trim out the plane for coordinated turns without any TX mixing. That make it easier for the AP to command.
Old Nov 11, 2013, 09:59 AM
HELModels's Avatar
Joined Aug 2003
#define ADVERSE_ROLL 0.2
servo_out[CH_RUDDER] = servo_out[CH_ROLL] * ADVERSE_ROLL;
That's basically how the original Ardupilot does it.
HELModels is online now Find More Posts by HELModels
Question Learning coordinated banked turns on quad Joe the Stack Multirotor Talk 16 Nov 07, 2013 01:13 PM
Discussion Coordinated Turns - I Hate to Admit Being Wrong Leo L Electric Warbirds 10 Oct 28, 2013 01:36 PM
Discussion Coordinated Turning? Ceratog Beginner Training Area (Aircraft-Electric) 8 Jul 18, 2013 10:42 PM
Coordinated Turn strouse Electric Plane Talk 7 Jul 22, 2003 12:30 AM
What the heck is a "coordinated turn"? Tim K Electric Plane Talk 18 May 14, 2002 05:30 PM
