Old Jul 11, 2013, 12:08 AM
1 OM KAR, SATNAAM
1satnaam's Avatar
GTA , Ontario
Joined May 2004
Can I run Mega 16 15 2 motor on??
Can I run Mega 16 15 2 motor on 4S with 60mm fan or 64mm fan??
let me know please.
satnaam
1satnaam is offline Find More Posts by 1satnaam
Old Jul 11, 2013, 01:24 AM
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
We've never run that one.
Here's the MEGAmotor spec for the 16/15/2.....The KV is 4180. 40A max. Says it pulls 36A on 3s in a Wemo minifan (70mm) on 3s.
Hardened stell shaft, diameter 3,2 mm.
Two precise ball bearings
Dynamically balanced
Neodym magnet rotor
Handmade stator, lightweight rotor allows high revolution.
Kevlar bandage rotor
Motor mount has two M3 threads for two M3 screws
Efficiency up to 88%
COMBAT version is designed for higer mechanical requirements, shaft diameter 5 mm.
Recommended gearbox: MEGA GEAR 16
Size and weight of these motors are the same as brushed motors of product line MIG 400. They have much better efficiency, power, max. revolutions and long lifetime. For example with motor MEGA ACn 16/15/8 and 8 cell aerobatic model you more than double the time of flight compared to MIG 400 motor.
Motors are also suitable for 50 - 70 mm diameter ducted fan.
At special request we can cupply also motor Mega ACn 16/15/4 with non-standart shaft with diameter 2,3mm. We can recommend this power drive for helicpoter models MicroStar 400 (Graupner) Zoom 400 (Protech) with weight 650 - 700 g, 3 cells Li-Pol 3S1P 1500 – 1800 mAh. 11,1V , current supply approx. 10A, recommended controller 25A. (more in "RC Revue 06/2005" magazine (pages.50-51) - in Czech).
Motor ACn 16 EDF:
recommended for 7-10 Ni or 2-3 Li cells
especially designed for ducted fan unit WEMOTEC Mini Fan 480, current up to 40A , (36A with 3xLiXX)
higgher torque
high current limit
dimensions: diameter x length - 28 mm x 41 mm
efflux RC is online now Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Jul 11, 2013, 09:00 AM
1 OM KAR, SATNAAM
1satnaam's Avatar
GTA , Ontario
Joined May 2004
Thanks Gary
satnaam
Old Jul 11, 2013, 01:21 PM
AKA Terry Till
ex-racr's Avatar
Alexandria, VA
Joined Apr 2002
let me know please.
satnaam
Satnaam, I'm using a HET 2w in a 60mm fan (Chinese copy of Alfa fan with 28mm motor tube). It is an equivalent to the 16/15/2, maybe slightly higher kv.
With the 5 bladed impeller IIRC I was getting about 30-32 amps on 3S (320-340 watts)
I then cut down a Freewing 64mm 5 bladed impeller and am now getting about 35ish amps and 370-380 watts.
Here's the plane, in my blog. It flies very well for the power it has:
http://www.rcgroups.com/forums/showthread.php?t=1511401
Based on my 3S results, the motor you have should handle 4S with the 60mm fan. I suspect it will also work with a 64mm fan on 4S too, but I haven't tried it.
60mm on 4S, definitely. 64mm on 4s, probably. Motor may be at its thermal limit for the 64mm fan, but that also depends on what fan you're using.
My .02
YMMV,
Terry
ex-racr is online now Find More Posts by ex-racr
Old Jul 11, 2013, 11:01 PM
1 OM KAR, SATNAAM
1satnaam's Avatar
GTA , Ontario
Joined May 2004
Thanks Terry
I will try the 3S and measure the Amps and then will try 4S and measure the Amps and will stay less then 45Amps.
satnaam
Old Jul 12, 2013, 09:10 AM
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
mega is under rated and very tough. it'll prob handle 4s in burst rather well.
stoneenforcer is online now Find More Posts by stoneenforcer
Old Jul 12, 2013, 11:02 AM
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
http://shop.wemotec.com/index.php?k=52&lang=eng
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Old Jul 12, 2013, 12:14 PM
High Dynamic Thrust
Joined Feb 2007
edf 3600kv and 16/25/1.5r is 3750kv? both are great on 4s in the wemo pro. I put a beating on them WOT entire flights and they handle it fine.
Old Jul 12, 2013, 03:05 PM
1 OM KAR, SATNAAM
1satnaam's Avatar
GTA , Ontario
Joined May 2004
Thanks for all you help Gents.
satnaam
Old Jul 12, 2013, 03:38 PM
AKA Terry Till
ex-racr's Avatar
Alexandria, VA
Joined Apr 2002
-but for 60mm and 64mm fans, the Kv may be a little low, unless you're using a Change Sun rotor
Old Jul 12, 2013, 04:01 PM
High Dynamic Thrust
Joined Feb 2007
smaller the fan, higher the KV. less loads
Sold Mega Motors 16/15/2 In-runner Jim Blanchfield Aircraft - Electric - Jets (FS/W) 1 Jul 01, 2013 12:22 PM
For Sale Mega 16/15/2, brand new, never run KRProton Aircraft - Electric - Power Systems (FS/W) 1 Jun 23, 2013 03:47 PM
Sold Mega motors 16-15-3 ! $40 shipped flyte lyne Aircraft - Electric - Power Systems (FS/W) 2 Apr 11, 2013 10:47 PM
Discussion Mega 16-15-2 motor wiring question NeilRivera High Performance 5 Mar 08, 2013 08:39 AM
For Sale Mega 16/15/2, 2x 16/15/5, 16/15/6 motors cheap! shschon Aircraft - Electric - Power Systems (FS/W) 1 Jan 26, 2008 12:18 AM
