Old Mar 07, 2014, 03:14 PM
Australia, WA, O'Connor
Joined Jan 2014
Originally Posted by Vantasstic View Post
I had tried using a head tracker some time back...hated the thing. Never could get it to center properly...among other things. Anyway, I like how you set your mixing up. That makes great sense and easily changeable at a flick of a switch. I might never try another HT, but to see some of the mixing available in the OpenTx, ER9X, etc. it opens possibilities for future ideas. Thanks for sharing.
If you want a tracker that works try this 1 for about $20 everybody who has it says how well it centers. I only have mine on the bench and have left it for long periods of time in different positions and then back to center and it gets it right every time.
http://www.rcgroups.com/forums/showthread.php?t=1677559
whimsical is online now Find More Posts by whimsical
Old Mar 07, 2014, 03:28 PM
spyder03's Avatar
United States, FL, St Petersburg
Joined Jan 2014
Originally Posted by Tomkfly View Post
No, if you have bound with no jumpers on the pins, Sbus is available on CH 1 to16 and Ch 1 to 8 is also available on the pins.
If you want CH 9 to 16 on the pins you need to bind with jumpers on the signal pins 1 to 2 and 3 to 4.
Tom
Much appreciated! I have to open her up to solder my new gimbal power cable anyway, so I'll re-bind with the appropriate process as well.
spyder03 is offline Find More Posts by spyder03
Old Mar 07, 2014, 03:39 PM
Northern Alabama, USA
Joined Apr 2003
Originally Posted by bertrand35 View Post
There you go, nightly build server is up: http://jenkins.open-tx.org/firmware/nightly-builds/
This builds the [next](https://github.com/opentx/opentx/commits/next) branch every night, with default options for Taranis only for now.
(snip)
Would be good to know what you think of it
- Of course any other bug you'd find!
Where is the "Stick Sides" function hiding? It used to be in the Sticks>Edit>Sides menu. I can't find it anywhere in the new Companion. I use this function a LOT, especially on elevator. The "Functions" option under "Curves" is not the same thing. Doesn't allow a variation of expo on each side of the stick movement.
Jon
jonlowe is offline Find More Posts by jonlowe
Old Mar 07, 2014, 03:49 PM
AMA 506547
punkindrublik's Avatar
United States, CA, North Highlands
Joined Sep 2004
Originally Posted by paktazh View Post
Sure Bro and i got the ch 15-16 free so if u can have a EEpe so i can add it to my existing EEprom thanks in advance
Check a few posts down from that one, already posted it
DONATE to OpenTx -
https://www.paypal.com/cgi-bin/websc...=DJ9MASSKVW8WN
punkindrublik is online now Find More Posts by punkindrublik
Old Mar 07, 2014, 03:57 PM
AMA 506547
Joined Sep 2004
should i just drop this to my existing Eeprom ???
I would open it next to your existing eepe, then copy and paste the headtracking functions. That way you don't load all of my settings to your radio.
DONATE to OpenTx -
Old Mar 07, 2014, 04:10 PM
Sparky "Electrics Rule"
bobf's Avatar
Mission, BC Canada
Joined Jul 2002
Has companion 1.99 not released yet I assume but sure has a different look and feel. I am kind of used to the old layout. New version is fancier. Seems to work ok though.
Edit
Has Play once, not at start up which is cool.
bobf is online now Find More Posts by bobf
Old Mar 07, 2014, 04:15 PM
mmatheny's Avatar
United States, TX, Dickinson
Joined Mar 2003
Is companion 1.99 only compatible with Next?
mmatheny is offline Find More Posts by mmatheny
Old Mar 07, 2014, 04:20 PM
AMA 506547
Joined Sep 2004
Edit
Crazy lookin! Got some playing to do now
DONATE to OpenTx -
Old Mar 07, 2014, 04:39 PM
United States, FL, Lakeland
Joined Jan 2014
New Taranis yesterday!
Bricked today Win7, XP, zadig, card out, new cable. I'm stumped. Any Taranis Pilots in Lakeland this weekend for Florida Jets?
olyflyz is offline Find More Posts by olyflyz
Old Mar 07, 2014, 04:47 PM
Joined May 2012
DONATE to OpenTx -
So the entire file that u uploaded is not just for head tracking ? if not what part is please i thought i could just copy the entire file that u uploaded to my EEpr
paktazh is offline Find More Posts by paktazh
Old Mar 07, 2014, 04:53 PM
AMA 506547
Joined Sep 2004
Actually, that eepe has no settings other than headtracking, so you can use it to start a new model. So yeah, you can just use that eepe.
Now if you want to add headtracking to an existing model that you already have set up, you just need to copy and past the mixes on channels 5 and 6 (in the mixes menu).
DONATE to OpenTx -
Old Mar 07, 2014, 05:03 PM
ttabbal's Avatar
United States, UT, Herriman
Joined Jan 2012
I doubt it's totally bricked. The bootloader in these is pretty hard to mess up. With the radio OFF, plug into the computer. Look in device manager for the ST Bootloader device. Is it there?
ttabbal is online now Find More Posts by ttabbal
Old Mar 07, 2014, 05:06 PM
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
Originally Posted by spyder03 View Post
So that means that Sbus represents channels 1-8, and traditional pins for 1-8 are now 9-16?
Here's how to think of it.
The TX can send any number of channels up to 16.
Depending on your receiver:
- traditional RX can support as many channels as they have pins for.
- a "pure" Sbus Rx would have not traditional pins, and would support up to 16 servos. Each servo can be programmed as to which channel it responds to.
- the XR8 is a typical "hybrid" Sbus Rx, which includes 8 standard pins and an Sbus connector. The pins are hard-coded for channels 1-8. Servos on the Sbus would typically be programmed in the range 9-16. I think there would be no problem duplicating an Sbus servo channel onto one of the traditional channels if that were useful. (i.e. ch 6 controls two servos: one plugged into traditional channel 6 and also an Sbus servo programmed to channel 6).
marhar is offline Find More Posts by marhar
Old Mar 07, 2014, 05:13 PM
AMA 506547
Joined Sep 2004
I'm sure this is a stupid question, but just to cover all bases, your battery IS plugged in AND charged, correct?
DONATE to OpenTx -
Old Mar 07, 2014, 05:19 PM
Tomkfly's Avatar
United Kingdom, England, Birkenhead
Joined Jan 2013
The X8R is not hard-coded for channels 1 to 8. There are 4 methods of coding it whils binding. CHs 1 to 8 with telemetry, 1 to 8 less telemetry, CHs 9 to 16 with telemetry and 9 to 16 without telemetry.
And simulioustainally outputs all 16 CHannels via Sbus.
Tom
Tomkfly is online now Find More Posts by Tomkfly
Discussion FrSky: what's your range and configration? not103 FPV Talk 687 Dec 12, 2014 03:54 AM
Help! FrSKY Telemetry not working? Greiswig Radios 12 Jun 01, 2014 09:26 PM
Discussion Passed by Obama's grandmothers appartement today ... logan5 Life, The Universe, and Politics 33 May 09, 2014 12:34 PM
Discussion Whistler's Grandmother in Classified Ads T6Junkie Auto Gyros 2 Sep 20, 2008 03:46 PM
For Sale Giant Size Auto-Gyro " Whistler's Grandmother T6Junkie Aircraft - Fuel - Airplanes (FS/W) 0 Sep 20, 2008 12:17 PM
