Old Oct 01, 2012, 06:58 PM
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
Error code.....problem?
I have 2x 4S Revolution (3 years old). I get LOTS of Safety Code 17 and 28 (I have read what the Code designation is), to the point of being quite annoying. It happens on old lipos, abused lipos, and even brand new lipos. Reset the button and it may simply do it again or go on with it's business. Unplug/replug seems to make little difference. Given enough patience and button pushing and it will finally complete the charge perfectly.
I am using short extension wires to minimize the constant plugging wear on the more critical required plugs. Removing the extension and plugging directly into the adapter does not seem to help the problem. If it were limited to the oldest batteries I'd chalk it up to worn connectors but its doing it on some brand new ones I have with the extension or directly into the adapter.
These (various) same batteries put in 2 other balance chargers I have charge and balance fine using the same short extensions.
I know these are very safe and easy to use chargers. I like and recommend them to folks all the time but the Safety Code hassle takes the issue of watching your batteries to the level of hovering over them to hit the damn button until it finishes.
Anything can be done about this?
BTW, it seems looking back it has always been kind of sensitive. I suppose I'm just less tolerant since I have 4+ years of lipo charging experience and have used other chargers that don't have this 'feature'.
Note - it seems to do this with charging. I always storage charge so am starting ~50%. When I storage charge AFTER flying I don't get these Safety Codes.
flydiver is online now Find More Posts by flydiver
Old Oct 01, 2012, 08:59 PM
President, FMA, Inc.
Tim Marks's Avatar
Joined Mar 2008
Hi:
I recommend you get ahold of some contact cleaner, spray every connector down and clean them using a toothbrush to get down inside them really good. Clean all your battery balance connectors, all your adapters, and the connector on the charger. Replace any of these items that you can from time to time as connectors are the first things to wear out. Most customers who follow these recommendations are successful at reducing or eliminating cell count and similar safety codes.
Tim Marks
Tim Marks is offline Find More Posts by Tim Marks
Old Oct 01, 2012, 10:50 PM
flydiver's Avatar
Joined Jan 2007
I'll try that and report back next battery charging session. Thank you.
Discussion My annoying Mini UFO! { Video } kapteinkuk Multirotor Talk 82 Mar 31, 2014 10:36 PM
Discussion Do ships with a Spider 2.5 wing type dihedral roll ok -or annoying? kewhite Slope 18 Jun 21, 2012 11:09 PM
Discussion Annoying DX6i problem, can you hack these things? signal15 Radios 2 Jun 17, 2012 11:44 PM
Complaint Internet driven adds totally annoying Azarr Site Suggestions / Complaints 1 May 08, 2012 10:37 AM
Help! hyperion EOS0610i duo erro PAULLEE Batteries and Chargers 4 Nov 26, 2009 08:22 AM
