Old Apr 04, 2012, 01:07 AM
Puerto Rico, Luquillo
Joined Feb 2012
Sealing radio box
Just got a used blackjack 26. The esc, servo and receiver are exposed. What have you guys done to seal them, use a traditional radio box? Or by just sealing the lid, it's good enough. I noticed it did not come with that plastic lid that goes under the cowling.
shovelnoserc is offline Find More Posts by shovelnoserc
Old Apr 04, 2012, 05:53 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Most of us just seal the hatch with hatch (hockey) tape.
bill34207 is online now Find More Posts by bill34207
Latest blog entry: 12 o'clock high 2014
Old Apr 05, 2012, 08:05 AM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Just to clarify a bit on what Bill said, it's clear hockey tape not the fabric tape for sticks.
wparsons is offline Find More Posts by wparsons
Old Apr 05, 2012, 10:32 AM
carlnoki's Avatar
United States, VA, Woodbridge
Joined Dec 2010
yepper, the clear hockey tape
carlnoki is offline Find More Posts by carlnoki
Old Apr 06, 2012, 09:34 AM
United States, FL, Titusville
Joined Dec 2011
You can put the receiver in a ballon with a tie or rubber band on the end. The esc, yes you prob. should put it in a radio box w/ the servo if possible. If the servo gets wet and goes bad you can get a traxxas waterproof servo pretty cheap on ebay. Just my .02 , hope I helped..
proboatronnie is offline Find More Posts by proboatronnie
Old Apr 06, 2012, 09:01 PM
Joined Feb 2012
Thanks, I ran it today. Sealed the lid and did not see any water while running it. It flipped twice and I removed the plug and no water came out.
But... Apparently some water got in and damaged one of my batteries, when I got home I found the small plug with the blue corrosion on it. While cleaning it two of the wires came apart. Can this be repaired, or is this a good excuse to get new batteries any suggestion on new batteries?
It's still has the stock motor and esc, running on two 2s 5000mah lipo's.
Also I have to read up on the stability of this boat, it was all over the place but it was a bit choppy.
Old Apr 06, 2012, 09:03 PM
Joined Feb 2012
Old Apr 07, 2012, 06:02 PM
Joined Dec 2011
I have 2 of those same exact batteries in my boat and never had any problems however I can say that deans plugs dont work together well from my experience in boats. If you stay with deans I would wrap the connections with electrical tape before you let it loose in the water.
Old Apr 07, 2012, 07:32 PM
Joined Feb 2012
I did wrap the red connectors, but not the lil white ones,that's where they broke. Is that it for the battery or can I repair it.
Old Apr 08, 2012, 07:04 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
The battery itself may still be useable. You won't be able to balance the cells though. That is the balance lead that has come apart on you.
Old Apr 08, 2012, 08:18 AM
osprey21's Avatar
Palma Sola,Fla.
Joined Oct 2006
I have a few Turnigy 2S balance leads I cut off of old bad batteries, they could easily be spliced to your existing leads. If you're interested, send me a PM and I'll mail you a couple, gratis.
osprey21 is offline Find More Posts by osprey21
Old Apr 08, 2012, 08:56 AM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Just put the wires back into the plug (in the correct order!!!) and hold them in with some thin CA applied from the back.
Old Apr 08, 2012, 09:03 AM
Joined Feb 2012
Thanks Osprey I'll pm you.
I cannot repair them as the terminals corroded. Gotta love salt water
Old Apr 09, 2012, 04:23 PM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
You can easily clean off the corrosion...
Old Apr 09, 2012, 07:37 PM
Joined Dec 2011
You could cut off the corroded ends or just get the new lead
For Sale New in sealed boxes. Robbe no. 8367 and 8361 controllers Felix C Aircraft - General - Radio Equipment (FS/W) 0 Mar 25, 2012 12:18 PM
For Sale 3GX Brand New in Box (Sealed) rotaryguy Aircraft - Electric - Helis (FS/W) 4 Mar 03, 2012 03:51 PM
For Sale HPI Baja 5B SS Kit with Motor ( New in sealed Box ) Price Drop Lenny7118 Cars - Cars and Parts (FS/W) 0 Feb 22, 2012 10:32 PM
Sold New still in the sealed box- Park 300 Diane@lazertoyz Aircraft - Electric - Power Systems (FS/W) 0 Feb 22, 2012 06:48 PM
For Sale radio boxes 18.00 w/ push rod seals Expresscraft Boats (FS/W) 2 Feb 16, 2012 10:50 PM
