Old Jul 10, 2014, 02:33 PM
United Kingdom, Walsall
Joined Mar 2013
After trying the shock, it's a bit better but I'm still getting the chattering.
I've got a few different springs to try and I'll try changing the oil.
I initially fitted the shock with some 80wt oil and if I'm honest there isn't much damping.
But at least I can now fit a normal 65mm shock easily even if these HK ones are a bit 'too cheap'
Syncro is offline Find More Posts by Syncro
Old Jul 10, 2014, 03:57 PM
canvey island
Joined Jul 2002
Nice job, I really like this sort of thing, did it myself to the Silverlit, its fun trying to get a toy to go like this
steve bisco is offline Find More Posts by steve bisco
Old Jul 10, 2014, 04:18 PM
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
That looks good, Syncro. I expect it's a big improvement on the red plastic one, and gives you more scope for experimenting with different oil and springs.
So the bottom end is still a ball linkage, just held by a stud from the left? I had some linkages from GiantCod once (before it got ruined and turned into GiantShark), that had a ball in them that was drilled through, so you could put a bolt through it. I guess it would be quite tricky to drill out an existing ball cup though.
Andy2No is offline Find More Posts by Andy2No
Old Jul 10, 2014, 04:25 PM
Joined Mar 2013
The bottom is drilled straight through so I can put a 3mm cap screw through from right to left.
Old Jul 10, 2014, 04:58 PM
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
I can see I was looking at it wrong, Syncro.. So, what about the top end? That looked like a bolt through it, but that didn't seem to be what you were saying in the comment on the picture.
Old Jul 10, 2014, 05:15 PM
Joined Mar 2013
Sorry, yes.
Top is bolt through too.
Old Jul 10, 2014, 05:33 PM
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
I see. Thanks.
Old Jul 23, 2014, 09:10 AM
Joined Mar 2013
Quick update.
I couldn't seem to get enough damping from the HK dampers so decided to seek an alternative.
Then it suddenly occurred to me I had a spare stock venom gpv1 damper from when I upgraded it.
Worth a try I thought and it turns out it fits nicely. It's a little longer but doesn't seen to be a problem.
Handling is noticeably better now as it's got a lot more damping at the rear.
Discussion Neu 1510/1.5/D Neu 1510.5/1.5/D Mlinaric L High Performance 4 Jul 11, 2011 04:17 PM
Rave I wish I read japanese (the Ultimate 1/5 HOR) Akura2 Motorcycles 108 Sep 22, 2008 08:03 PM
Discussion 1/5 HOR??? YouTube. Check it out Kev71H Motorcycles 1 Apr 28, 2008 11:52 AM
Video 1-5 HOR "KOBA_spl 2" J1_HEN Car Talk 3 Jan 13, 2007 05:29 AM
Discussion Anyone selling a 1/5 or HOR? dr.bjm Motorcycles 2 Oct 16, 2006 07:25 PM
