Old Apr 01, 2003, 12:58 AM
MSu1049321@aol.com
Guest
n/a Posts
[RCSE] Re: Soaring V1 #1441
There must be a 'legal' way to make decent smoke for gliders without pyros.
What about smoke fluid and an electric coil? Short duration, but it should
work okay...
A while back, I was designing a 2-meter fuse with a reservoir of bubble fluid
and a deployable set of wands that could give you a continuous "bubble
trail"... Complicated, but doable, unfortunately the name "Bubble Dancer"
seems to be taken;-) Not quite the same as "smoke on"......
RCSE-List facilities provided by Model Airplane News. Send "subscribe" and "unsubscribe" requests to soaring-request@airage.com. Please note that subscribe and unsubscribe messages must be sent in text only format with MIME turned off.
Brett Jaffee
Guest
n/a Posts
Re: [RCSE] Re: Soaring V1 #1441
If it got hot enough I'm sure it would work. You can buy electric pump
smoke systems that they make for scale aerobatic planes, so that part isn't
a problem, at least.
Brett P Jaffee
Programmer
TechEmpower
tel: 310-524-1700 x254
fax: 310-524-1701
bjaffee@techempower.com
www.techempower.com
