Old Feb 11, 2014, 08:40 PM
Gadgetman's Avatar
Australia, SA, Adelaide
Joined Jun 2004
Very Loud Lost Model Alarm Using Turnigy Receiver Controlled Switch
The Lost Model Alarms I've tried are too quiet for me. This one is 105dB which is VERY LOUD. I suggest you wrap it in a sock while setting up on the bench!!
It's just a 'Turnigy Receiver Controlled Switch' attached to the white Piezo Buzzer as in the photo. I'm powering the unit from the 3S balance connector.
The buzzer came from Jaycar Electronics in Australia, check your local eBay. It has 3 wires, black for negative, red for constant tone, yellow for chirp tone.
All up weight is 28gm (1oz). Size is 45mm (1.8") diameter x 30mm (1.2") high.
Throw the gear switch on the transmitter and (if your electronics are still intact) the buzzer will sound and you can go look for the remains.
If you want to run a separate battery then you need to wire the negative from that battery to the receiver negative as in the photo.
You may need to adjust trim on the gear channel so it switches reliably.
I remove the shorting plugs and bridge the upper and lower pin pairs with solder.
Thanks for the idea Frank!
Gadgetman is online now Find More Posts by Gadgetman
Discussion Turnigy 9x + Frsky + lost model alarm rbwins1 Multirotor Talk 8 Nov 10, 2013 09:05 PM
Off Site New lost model alarm, compact, LOUD, light and Spektrum compatible PLD Aircraft - General - Radio Equipment (FS/W) 6 Aug 26, 2009 08:24 AM
Sold Lost model alarm Loud $10 shipped mrfliboy Aircraft - General - Miscellaneous (FS/W) 5 Dec 13, 2008 05:12 PM
Discussion Lost Model Alarm for use with Hitec Micro 5 Receiver larjim Foamies (Kits) 2 Jun 29, 2007 04:45 PM
