Old Dec 25, 2013, 04:46 PM
QDRevenger's Avatar
New Zealand, Auckland
Joined Jun 2011
Need some help, 86" Extra 260 with DLE55
Hey guys,
Not sure if I have this in the right section but I need a bit of help with my build.
I'm building an Aeroworks 86" Extra 260 Original with a DLE55. I wired up the radio gear and the ignition on separate circuits. Here is a drawing of how I wired everything up.
Description:
I have Hyperion high voltage servo's, HP-DH20FTD for ailerons and elevators and a HP-DH20UTD for rudder. Im not running a voltage regulator for the radio gear and using a 2S 2250mAh Lipo for the power supply. I have set up the ignition system on it's own circuit with a 2S 2250mAh lipo with a UBEC regulating to 6V. The ignition module says that the voltage input can be from 4.8-6V. I am using a Rexell opto kill switch in line (input voltage 20v max).
The radio system works fine, no drama, I've set all the throws and operated everything. When I turned on the ignition system everything was still working, I was programming the gear switch on the TX for the engine kill, then I noticed the LED on the opto kill switch slowly went out, the kill switch was hot and now the LED won't come back on. I suspect I have fried it Hope I haven't fried the ignition module too. Has the higher voltage from the RX signal into the kill switch fried it?
Can somebody please help me, tell me what I have done wrong and point me in the right direction, before I do any more damage. Thanks in advance.
QDRevenger is online now Send a private message to QDRevenger Find More Posts by QDRevenger
QDRevenger is offline Find More Posts by QDRevenger
Old Dec 28, 2013, 07:47 PM
bigblueswope's Avatar
United States, GA, Loganville
Joined Aug 2012
Try programming the gear channel's end points. It may not be triggering the opto kill. I hav ethe same opto kill on a 2S lipo and no issues. I had to reverse the gear channel and change the epa.
bigblueswope is offline Find More Posts by bigblueswope
Discussion Need some help with Remzibi OSD sroyj FPV Equipment 8 Jul 30, 2014 11:37 AM
Discussion Need some help, 86" Extra 260 with DLE55 QDRevenger Engines 5 Jan 03, 2014 02:35 AM
Discussion need help with some math crazy speed Electric Plane Talk 21 Dec 02, 2013 12:23 AM
Discussion Need some help with Landing Gear Sheer Pins Chuchuf Large EDF Jets 5 Sep 26, 2013 07:33 PM
Help! Help i have a pa extra 260 i need some motor advice theone_23 Beginner Training Area (Aircraft-Electric) 16 Jan 28, 2009 12:25 PM
