Old Feb 26, 2013, 07:18 PM
Joined Oct 2012
Flaperons or Spoilerons settings DX6i
I have the DX6i running a 6 channel receiver on my Stinger 64 EDF. Problem I'm experiencing is the amount of landing area this jet requires, it comes in hot with nothing to slow it down.
Is there any way to set up the transmitter to slow it down by either flaperons or spoilerons. Not even sure if its possible or which I should use. The jet is currently 4 channel.
pizatio is offline Find More Posts by pizatio
Old Feb 26, 2013, 08:32 PM
Registered Voter
Tepid Pilot's Avatar
South Central Texas
Joined Aug 2009
http://www.horizonhobby.com/pdf/DX6i-Manual_EN.pdf
Page 12. HTH.
TP
Tepid Pilot is offline Find More Posts by Tepid Pilot
Old Feb 26, 2013, 08:45 PM
OY-5542
Chrizz's Avatar
Denmark, Central Denmark Region, Silkeborg
Joined Nov 2009
...and you can get both, even tough the flap-switch only has two positions!
Copy/paste from an earlier post of mine (post #9 http://www.rcgroups.com/forums/showt...hp?t=1571413):
"By the way, here's a tip I'm quite happy to know.
I regret not to have a 3 position flap switch on my Dx6i (it's a 2 position switch, which usually means your flaps are either deployed or not).
Well, I regret not to be able to have the choice between; no flaps, a bit and fully down.
Then I figured out that, if the plane is mechannically trimmed to neutral, I could, when programming the flaps as undeployed, set the value to a symbollic '1'. Then with the Tx's electronic trims, trim the plane back to neutral.
Now we have a neutral trimmed plane again, but with a symbollic value programmed for when flaps are undeployed.
This allows to use a free mix: Flaps >> Flaps, activated by any switch (I tend to use the elevator D/R switch, next to the flap switch) and use the mix's value settings to trim the flaps travel.
And there you go, you now have a 3 position functionning flap, but on two switches. The downside of this solution is the lack of elevator compensation, when flaps are deployed through the mix.
I've used this solution for, i.e., a Multiplex Merlin (hotliner glider, 78cm wingspan, 365g). The original flapswitch was set for spoilerons and the mix, described above, for camber/extra lift-flap. On this plane the lack of elevator compensation didn't matter at all. In fact, for a smaller amount of flaps, it hardly needed any compensation."
You can make a variation of this, by programming spoilerons and flaps instead of two different deployed flap positions(plus neutral).
Happy landings :-)
Chrizz is online now Find More Posts by Chrizz
Discussion HK 2M ask-21 flaperons OR spoilerons???? rtbates Scale Sailplanes 4 Feb 24, 2013 05:00 PM
Help! Jart Control Throws + flaperon/spoileron settings Marcelo Blumm Slope 1 Feb 04, 2011 11:41 PM
Mini-HowTo How I set up the DX6i for spoileron/flaperon on throttle stick crusius Slope 1 Jun 25, 2009 10:26 PM
Flaperons or Spoilerons on My Vortex CC? Joe Elston High Performance 22 Feb 15, 2003 05:15 PM
Flaperons or spoilerons?? DaleM Electric Sailplanes 43 Feb 06, 2002 06:39 AM
