Old Sep 25, 2014, 03:55 AM
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
Thanks for the info
So the ECO version is just with a HET housing ?
What size collet is included with the Jetfans ?
Are the Jepe JET90 fans also jetfan 90 rotors and het housings ?
http://www.jepejets.com/jepeshop/23-fan-units
And the Wemotec midifan EVO only accepts 36mm motors right ?
Will the EVO rotor work in a HET 90mm shroud then ?
Why is the jetfan website so bad......none of the links work, and the english page has never worked, and the information is sparse.......It doesn`t realy invite you to buy their products.....
SJ is offline Find More Posts by SJ
Old Sep 25, 2014, 04:25 AM
EDF Jet Jam May 2014
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
The collet is 5mm.
JP builds really smooth running fans. A friend has one of the Storm 90s in the Black Horse L39 on 12s the current draw is 81 amps settled on TP 3850 70C packs it pushes this large model quite nicely.
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Sep 25, 2014, 05:37 AM
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
I have a midifan housing, and the hobbyking 1600kv motor, and also a old het 1600kv motor for a 6S setup
Which jetfan rortor should I order to fit the midifan housing ?
The V2 or ECO rotor ?
The ECO rotor is a little smaller in diameter right ?
Old Sep 25, 2014, 08:41 AM
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
There are other housing options, I have Extreme CNC alloy housings in 90mm, both 36mm motor housing and 39mm motor housing, I designed them around HET 650 and 700 series motors. Also have Jetfan and EVO rotors to suit so if you wanted a complete fan to suit a particular motor its no problem. The HET housing will work but its not ideal, 4 stators instead of 5. The Wemo housing wont work with the jetfan rotor as the motor section is shaped at the front to suit the hollow back of the wemo rotor. It will be messy and the collet will be a long way out on the motor shaft.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Sep 25, 2014, 11:36 AM
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
Thanks for the info....that slims my choices down :-)
I would love to order stuff around the world, but there are just too high customs fees and VAT that have to be paid once you buy stuff outside of the EU over here in Europe, that stuff is just too expensive.....
Sold ESM 80" T-28 Trojan Electric w/ Sound + Smoke realdeal Aircraft - Electric - Airplanes (FS/W) 10 Oct 06, 2011 01:15 AM
Sold brand new never used power 90 e flite brushless motor Jakedizzle Aircraft - Electric - Power Systems (FS/W) 0 Sep 12, 2011 10:07 AM
Discussion My prop is hitting the sound barrier... OR... tom66 Power Systems 11 Aug 13, 2011 12:54 PM
Discussion Wemotec Midi vs Stumax 90 - Sound Comparison dro56595@bigpo Electric Ducted Fan Jet Talk 36 Jan 09, 2011 08:12 AM
