Old Dec 31, 2008, 02:57 PM
bobandris is offline
Find More Posts by bobandris
LSF 004 - AMA 5055
bobandris's Avatar
United States, CA, Saratoga
Joined Dec 2000
Brushless A10 Rotor Removal - HELP!
This is a call for help in getting a rotor off its prop adapter,intact.
I've got a BananaHobby Brushless A10. I'm pretty sure one of the rotors needs to be balanced. First off, one is more noisy (like a vibration) than the other. Second, bench testing shows a large, to me, difference in performance between the two. Here's test results using my crude static thrust stand (I didn't get rpm, however, I think I can, if you guys deem it necessary).
Particulars are:
3200 KV inrunners
54 mm/6 blade rotors
18 Amp ESCs
3S1P Xcite 1800/25C
Left Motor/Fan . . . . . . . Right Motor/Fan
11.98 V . . . . . . . . . . . . 11.98 V
12.70 A . . . . . . . . . . . . 11.00 A
152 W . . . . . . . . . . . . . 132 W
125 gm static thrust . . . . 142 gm static thrust
So as you can see, the left one is producing less thrust, while drawing more current. It also is the noisy one. I'd like to get the rotor off the prop adapter to try and balance it. But, I can't see how to do it without destroying it.
The motor end of the prop adapter is set screwed to the motor shaft. The rotor end of the prop adapter is axially drilled and tapped for a rotor retaining screw. The hub of the rotor shields any access to the shaft. I've tried reaching in to get ahold of the rotor hub but it won't pull loose.
So you see what I'm faced with, hopefully someone can shed some light on expert removal.
Many Thanks,
Bob
bobandris is offline Find More Posts by bobandris
Old Dec 31, 2008, 03:39 PM
kelberts is offline
Find More Posts by kelberts
Effumall
kelberts's Avatar
Joined Nov 2005
Almost no way to do it w/o breaking something. I just cut it off and buy a new rotor, or even a whole new fan. They're what, like $2.50?
http://www.allerc.com/index.php?cPat...f5d27735b89397
http://www.bphobbies.com/view.asp?id=B1098405
kelberts is offline Find More Posts by kelberts
Discussion Help with Havoc rotor removal! :( Plastic_Avatar Micro Ready-to-Fly 5 Jan 27, 2008 02:42 AM
Rotor Removal Help, GWS EDF 55 Rich Uravitch Electric Ducted Fan Jet Talk 7 Jul 16, 2005 11:26 AM
Corona tail rotor washer. Help... nrthwing Electric Heli Talk 6 Dec 23, 2002 10:43 PM
advice on building a brushless twin rotor fan Doc Dyer Electric Ducted Fan Jet Talk 3 Feb 19, 2002 10:57 PM
Aluminum tail rotor bushing..... help................. DH Electric Heli Talk 2 Jul 09, 2001 12:05 AM
