Old Jan 02, 2005, 04:14 PM
jeremyl_13 is offline
Find More Posts by jeremyl_13
Joined Dec 2004
Cant decide on first float plane
In the last two days i've lost two planes. First off was a gws spitfire from being underpowered it only lasted 3 short flights, and 2nd was a parkzone j3 cub due to tx/rx interfearance. In the 3 years I've flown i've never totaled a plane so right now i'm sorta bummed. But at least i've been bit with the seaplane bug right? So my thing is I need a plane that builds quick or ARF that would be a great 3 channel seaplane. It has to be electric also. I do have a hobbico superstar EP that hasn't been flown yet, no charger, LHS says it's on back order. Anyhow should I set this up as a float plane or go for a completely different plane? I was thinking if I went new to get a gws beaver or a herr j3 cub. Any idea which is the best route? I'm also looking to keep cost down a bit like under $100 for the plane/motor combo.
jeremyl_13 is offline Find More Posts by jeremyl_13
Old Jan 02, 2005, 04:42 PM
Vyceroy is offline
Find More Posts by Vyceroy
G G Ghost Pirates !!!
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
Basic 3 channel and simple and under 100.00 .. i would try a Slow stick .. a GWS Cub .. or an E Starter ..or the GWS Beaver.. all are good cheap first float planes ..
Vyceroy is offline Find More Posts by Vyceroy
Old Jan 02, 2005, 05:36 PM
Joined Dec 2004
Ok how does this setup sound. It's all from tower. Gws beaver with 350c, gp electrifly c-10 esc, gp electrifly peak charger, Gws 7.2v 600 mah nicd and gws floats. for a little over $100 not including servos. Would that have enough power to pull off the water within say 50 ft?
Old Jan 02, 2005, 07:35 PM
Aceshigh84 is offline
Find More Posts by Aceshigh84
Snoopy's Wingman
Aceshigh84's Avatar
Minneapolis, MN
Joined Dec 2004
With the 350c it should have no problem getting out of the water. I am assuming it is a DS gearbox. Some have had gripes about the weight or water tightness of the gws floats. A good alternative if you have a couple extra hours can be found in jimsp's thread. Good luck.
Aceshigh84 is offline Find More Posts by Aceshigh84
part 2 of help on first homemade plane devilscries Modeling Science 2 Jun 01, 2004 11:17 PM
help on first arobatic plane ??? dennis blocker Fuel Plane Talk 5 Apr 08, 2004 10:06 PM
help on first arobatic plane ??? dennis blocker Fuel Plane Talk 0 Apr 01, 2004 10:48 AM
Help me decide on a EPP 3D plane! rdalcanto 3D Flying 6 Dec 22, 2003 10:43 PM
What's a good, inexpensive first float plane ? Al P Foamies (Kits) 8 May 08, 2002 02:52 PM
