Old Aug 13, 2014, 06:47 AM
humbertomelo is offline
Find More Posts by humbertomelo
Brasil, GO, Goinia
Joined Feb 2009
Build Log
F-22 Raptor - Dual 90mm EDF
Hi people, I am starting a new project, the awesome F-22 raptor. I decided build this one, when i saw a great project here on RCgroups from Nem3 user. The project needs a lot of adjustments but i did it, lets try this F-22 in a larger scale and two 90mm EDFs.
Original F-22 Project:
RCGroups: http://www.rcgroups.com/forums/showthread.php?t=805557
Basic measures:
Fuselage: 1900mm
Wing: 1300mm
Details:
2 EDF 12 blades 90mm ~ 1500kv
2 ESC 120a
Lipo: 6s 5000ma or 8s 5000)
7 Servos 17g Metal
3 Metal landing gears
Humberto Melo
Jet builder addict
Starting with 3D images
humbertomelo is offline Find More Posts by humbertomelo
Old Aug 13, 2014, 07:15 AM
Brasil, GO, Goinia
Joined Feb 2009
After a few weeks working on 3DMax, i finished my modifications
1- Add landing gear spaces
2- Re-scale from 70mm to 90mm EDFs
3- Add lipo plataform and rescale structure for larger lipo capacity.
4- Add structure for air intake duct
5- Improved vector thrust mechanism
Pieces for laser cut:
Old Aug 14, 2014, 01:49 AM
pajlotmato is offline
Find More Posts by pajlotmato
Slovakia, Veľk Krt
Joined Dec 2006
next great project in your creating, subscribed...
pajlotmato is offline Find More Posts by pajlotmato
Old Aug 14, 2014, 03:21 PM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2015, May 28-31st
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Subscribed!
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Aug 16, 2014, 04:14 PM
raipe is offline
Find More Posts by raipe
raipe's Avatar
Finland
Joined Oct 2008
subbed in!
raipe
raipe is offline Find More Posts by raipe
Old Aug 18, 2014, 02:25 PM
Brasil, GO, Goinia
Joined Feb 2009
Working on vector thrust design.
F 22 Vector (0 min 9 sec)
Old Aug 18, 2014, 03:35 PM
VIDEOPRO is offline
Find More Posts by VIDEOPRO
VIDEOPRO's Avatar
Central Maryland
Joined Apr 2008
Looks good. Will be watching as I am in the process of building one myself. Twin 90mm EDF F-22. One thing I will be watching on yours is the location you have your EDF units and how your COG works out. Can I ask how you figured out that location? I have my fan units further back so the front leading edge of the fan units are sitting at the leading edge of the verticals. My experience working on smaller F-22's provided me with the knowledge of fan placement location in order to fit the battery just behind the cockpit area and just in front of where the two ducts come in toward the center of fuse. This worked out good for my COG and I did not need to add any weight. So I am applying the same locations for my larger project. The concern I have on my build is, will the ducting be to long of air travel to the EDF units. I will need to post my build log so we can watch each others.
Already started building and have everything electrical. Using combination of foam and wood structure. Hot wire foam bulks and cut several wood bulks.
My specs:
76" length
55" WS
90mm 1950kv 6 blade metal lander units
Will be using two 6s 5000mah packs
VIDEOPRO is offline Find More Posts by VIDEOPRO
Old Aug 19, 2014, 09:45 AM
Brasil, GO, Goinia
Joined Feb 2009
The position of both edfs are based on weights of EDFs, Lipos, Escs and the F-22 geometry. The large duct length are not a problem, since i tested large ducts lengths in others projects (Mirage 2000 120mm edf, Habu 120mm edf) and is not a issue, at least in large and powerfull setups...
Old Aug 19, 2014, 09:46 AM
Brasil, GO, Goinia
Joined Feb 2009
Assembling the wood structure.
Old Aug 19, 2014, 10:24 PM
Brasil, GO, Goinia
Joined Feb 2009
Updating the building with some balsa covering.
Old Aug 20, 2014, 09:54 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
humbertomelo, another fine aircraft from the stables of humbertomelo!!
I'm hoping to get a look at the F-22 this weekend, during our Duluth Air and Aviation Expo - 2014 . First time we have had one here for the air show.. While I can't be on site to watch the demo, I should be able to see a great deal of if it just from my yard!
The main headliner --- The Blue Angles.
Lots of other great performers too!!
http://www.duluthairshow.com/2014/performers.html
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Aug 20, 2014, 11:28 AM
Lt599 is offline
Find More Posts by Lt599
Lt599's Avatar
United States, WA, Shelton
Joined Feb 2012
Looks amazing, very nice sized model, gotta love the F22 Do you have your own lazer cutter, or do you hire it done?
Lt599 is offline Find More Posts by Lt599
Old Aug 20, 2014, 12:40 PM
Dirty Dee is offline
Find More Posts by Dirty Dee
Dirty Dee's Avatar
United States, IL, Northbrook
Joined Sep 2011
Subbed.
I enjoyed following Nem3's F22 thread, but it was a bit of a shame that there was only 2 people building his plans, and neither of them have been finished or maidened yet.
Dirty Dee is offline Find More Posts by Dirty Dee
Old Aug 21, 2014, 07:14 AM
Brasil, GO, Goinia
Joined Feb 2009
Lt599,
I hire the laser cutter, i dont have one...
Old Aug 21, 2014, 07:34 AM
Brasil, GO, Goinia
Joined Feb 2009
Dirty Dee,
Yes unfortunately the Nem3 F-22 post has not ended... It is a great project, with some modifications will be the best F-22 plans! I will not sell this project, i will try to contact Nem3 and try to get his permission for put the cad modified project here on RCgroups.
For Sale New Haoye F-22 Raptor ART twin 65mm edf hproa Aircraft - Electric - Jets (FS/W) 0 Aug 09, 2014 10:47 AM
For Sale Twin 70mm EDF composite F-22 Raptor Tspine Aircraft - Electric - Jets (FS/W) 8 Jul 19, 2014 12:48 PM
For Sale Sapac F-22 Raptor 4 Ch,Twin 64mm EDF pnp Forrest Gump 23 Aircraft - Electric - Jets (FS/W) 0 May 21, 2014 01:50 AM
Sold Sapac F-22 Raptor - Dual EDF - Lowered Price!!! omster Aircraft - Electric - Jets (FS/W) 3 Sep 26, 2011 02:58 PM
Sold FlyFly f-22 raptor edf 90mm for sale... gazza1 Aircraft - Electric - Jets (FS/W) 3 Sep 07, 2009 08:38 AM
