Old Mar 22, 2014, 04:27 PM
bernie is offline
Find More Posts by bernie
USA, IL, Peoria
Joined Feb 2002
24 mm reloadable motor hardware
I've only used Estes engines, and I am going to purchase 24mm reloadable motor hardware and wanted to know If I should get Aerotech or Cesaroni, probably the 3 grain case. Based on what I Iaunch, what would be your recommendation? Thanks
bernie is offline Find More Posts by bernie
Old Mar 22, 2014, 08:46 PM
ttabbal is offline
Find More Posts by ttabbal
ttabbal's Avatar
United States, UT, Herriman
Joined Jan 2012
I like them both. I would think about what type of load you want to burn. The thrust curves tell you a lot.
In general, Cesaroni are faster and easier to build. The loads are usually a little more expensive though. For Aerotech, watch the delay assembly. If you put them together wrong, you can get a burn through.
One of my favorite 24mm loads is the Aerotech F12. A slower burn, thick black smoke, and similar thrust to a D12 so most Estes 24mm rockets fly great with it.
ttabbal is offline Find More Posts by ttabbal
Old Mar 23, 2014, 09:29 AM
WillMarchant is offline
Find More Posts by WillMarchant
United States, VA, Winchester
Joined Aug 2005
And I try to fly whatever my local hobby vendor carries in stock. That saves on shipping fees and also supports the vendor. Both those product lines are fun.
WillMarchant is offline Find More Posts by WillMarchant
Old Mar 23, 2014, 09:42 AM
ttabbal is offline
ttabbal's Avatar
Joined Jan 2012
That's a good point as well. Another option I just remembered...
http://www.valuerockets.com/default.aspx
Aerotech sells single use AP motors in 18mm and 24mm sizes that are priced competitively to black powder motors. They sell reload gear there as well. Just in case your local store doesn't stock some things you want.
My favorite local vendor is just a guy that comes to the high power launches and sells motors on site. He will order things for me if he doesn't have them and is a great resource for advice. And I get to watch the big stuff fly while I'm there.
Old Mar 07, 2015, 07:15 AM
Bob Jablonski is offline
Find More Posts by Bob Jablonski
Joined Mar 2015
If you don't have a local vendor or hobby shop that carrys mid power. I would go with Aerotech. due to the Hazmat shipping charge on all CTI reloads.
Mr. Bob
Countyline Hobbies
Grovertown, IN.
574-540-1123
countylinehobbies@yahoo.com
www.countylinehobbies.com
Bob Jablonski is offline Find More Posts by Bob Jablonski
Old Mar 07, 2015, 10:14 AM
CF105 is offline
Find More Posts by CF105
Arrowhead
Joined Dec 2010
I'm a hardcore CTI fan. However based on what's in that photo I'd suggest using Aerotech's single-use 24mm motors. Those ships will go like stink! No sense risking loss of the casing if you don't get the rocket back.
CF105 is offline Find More Posts by CF105
Old Mar 07, 2015, 10:48 AM
Joined Mar 2015
Good point. The E-20 or F44's should put them up.
Mr. Bob
Countyline Hobbies.
Grovertown, IN.
574-540-1223
Question LONG high K V 28 mm motor for 64 mm EDF. cyclops2 Power Systems 12 Dec 16, 2013 01:47 AM
Wanted Motor Mounts/Misc Motor Hardware vcaruso Aircraft - Electric - Power Systems (FS/W) 4 Nov 17, 2013 03:49 PM
Sold Turnigy G60 Brushless Outrunner 400kv motor and EP Motor Mount with Hardware danpos Aircraft - Electric - Power Systems (FS/W) 0 Nov 01, 2013 04:56 PM
Discussion HPI FLux vapor reload V2 + HPI flux shot motor vs LEopard V2 combo SpeedDemon888 Electric Power Cars 3 Oct 10, 2013 08:43 AM
New Razor 24 mm motors JPHen Electric Ducted Fan Jet Talk 12 Nov 15, 2004 03:37 AM
