Old Nov 07, 2013, 04:18 AM
IFLYGLIDERS is offline
Find More Posts by IFLYGLIDERS
IFLYGLIDERS
France, IdF, Triel-sur-Seine
Joined Mar 2013
Build Log
G650 build
Hi !
Here's my Gulftream G650 depron build :
SCALE 1/25
Lenght = 1.22 m ( around 48'')
Span = 1.13 ( around 44'')
weight unsure cause unfinished but under 700/800g expected all equiped.
2 x 55mm edf + 2 20amps esc and 3s 2200/2600 mah
4 x 9g types servos (2 ailerons + rudder + elevator).
And where I am...stoped right now hum let say unshure about key choices to finish it...
where to put battery tray and how to hold it safely but lightly?
how to attach wings to the fuse with drowned nuts and 4mm plastic bolts I have?
Strong skin to resist belly landigs on grass because no landing gear?...probably with craft paper and wood glu
light strong but accurate engines nacelles?
I read and read again all the building posts that could look like mine ( same technic or same airliner architecture :727's, erj's, dc9's etc...)
so anyone who want to suggest me anything is VERY MUCH welcome!!!!
IFLYGLIDERS is offline Find More Posts by IFLYGLIDERS
Old Nov 07, 2013, 04:25 AM
IFLYGLIDERS
Joined Mar 2013
EDF mounting
2 plywood piece with + V angle (as the real one)
55mm edf weight 70gr with motor + 20g by esc so that would be around 180g (around 6.5 OZ)
pretty heavy for such a small airplane ????
Old Nov 08, 2013, 04:51 PM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
G650-Thumbs-UP!
Sir your G650 is so Sweet you get my thumbs-Up!
demondriver is offline Find More Posts by demondriver
Latest blog entry: 4-Years in the Making!
Old Nov 09, 2013, 12:05 AM
Halownr is offline
Find More Posts by Halownr
Corporate Jet Mech
Halownr's Avatar
KVNY
Joined Oct 2006
Great project
Had an opportunity to work on one recently....very graceful in its lines, so much more than the GIII's and GIV's...huge tail on those beasts..
Will be watching your progress. KUTGW
Halownr
Halownr is offline Find More Posts by Halownr
Old Nov 09, 2013, 03:27 AM
IFLYGLIDERS
Joined Mar 2013
thank you demondriver!!!
I whish I could be as good as you and your fellow friends out there...
Now I have to finish it or shame on me!
see ya
Old Nov 09, 2013, 03:41 PM
carrerars is offline
Find More Posts by carrerars
carrerars's Avatar
Joined Aug 2008
LOVE IT !!!!!
I think the weight won't be an issue.
Gulfstreams are the best.
Markus
carrerars is offline Find More Posts by carrerars
Old Nov 10, 2013, 05:43 PM
IWC is online now
IWC
Find More Posts by IWC
IWC
Joined Feb 2003
Subscribed, and hoping for plans.
IWC is online now Find More Posts by IWC
Old Nov 11, 2013, 06:00 AM
IFLYGLIDERS
Joined Mar 2013
Hi!
plans are home made, taking a 3 view diagram and scale it into autocad (scale 1/25) then trace the side and upper lines.
Then a few inovations especially for tail that do not appear on my DWG plan.
Anyway I can put it online if you want, no problem
Old Nov 12, 2013, 09:27 AM
Up-Out-&-Gone
Joined Mar 2007
Your G650 Plans look great Sir!
Old Nov 12, 2013, 08:14 PM
Doushiyou12 is offline
Find More Posts by Doushiyou12
Winter Is Coming
Doushiyou12's Avatar
Joined Feb 2010
Subbed. Looks great!!!
Watching out for updates
Doushiyou12 is offline Find More Posts by Doushiyou12
Old Nov 13, 2013, 11:01 AM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
How did you export the PDF plans at the right size from autocad?
Keenan smith is offline Find More Posts by Keenan smith
Old Nov 13, 2013, 12:54 PM
IFLYGLIDERS
Joined Mar 2013
watch out I'm not shure the pdf plans are at the right size.
In fact I imported a 3 view image in autocad as raster, then I scaled the image to 1/1 scale with the real one datas, then I copy this image to a 1/25 scale and only then I drew the lines over the image.
I exported the DWG to pdf
Old Nov 13, 2013, 12:58 PM
IFLYGLIDERS
Joined Mar 2013
wing upper panels done with 3mm depron
Old Nov 13, 2013, 05:17 PM
Up-Out-&-Gone
Joined Mar 2007
She's looking superb Sir, Love her wings!
Build Log My First Kit Build Contender build chaos2984 The Builders Workshop 100 Nov 06, 2013 08:28 AM
Discussion Build or not to build? cessna20122013 Electric Plane Talk 14 Feb 14, 2013 11:26 PM
Discussion My First Kit Build Contender build chaos2984 Electric Warbirds 2 Jan 28, 2013 08:29 AM
