Old May 07, 2013, 12:40 PM
xzodiackxs is offline
Find More Posts by xzodiackxs
Joined Jun 2012
Sullivan Skywriter question
I ordered the sullivan sky writer but I'm confused as of where the smoke comes out . Is it from the same muffler I will use on my dle or an external one ?
xzodiackxs is offline Find More Posts by xzodiackxs
Old May 07, 2013, 01:30 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
The oil is pumped into the engines standard muffler.
I just came across the instruction sheet on the web if it helps -- http://www.sullivanproducts.com/S753...structions.pdf
eflightray is offline Find More Posts by eflightray
Old May 07, 2013, 02:15 PM
Joined Jun 2012
So I'll have to drill a hole in my muffler specifically for the oil , other than the one that draws the oil from the engine and pump it out the muffler ?
Old May 08, 2013, 06:36 AM
Cougar429 is offline
Find More Posts by Cougar429
Cougar429's Avatar
Canada, ON, Windsor
Joined Apr 2008
There are a few other important considerations. The key to getting good smoke is to preheat the oil charge before directly injecting it into the hot exhaust gas stream. This is usually accomplished with a preheater coil routed internally in the muffler, (basically what you get with a "Smoke Muffler") but can be external and relatively easy to build.
I have an excellent .pdf file describing most of what you need to know. Don't know how to add that here, but this page has a link to the file at the top:
http://tmenet.com/products/smoke-sys...ret-smoke-tips
Cougar429 is offline Find More Posts by Cougar429
Old May 20, 2013, 07:29 AM
Low Hover is offline
Find More Posts by Low Hover
Joined Aug 2009
I agree with Cougar, preheating the fluid helps a lot. I never bought a 'smoke muffler' I purchased some copper tubing and wrapped it around the head of the engine (with the help of a propane tourch for smooth bending) and it works pretty good. The best part of the Sulivan smoke pump is the ability to adjust the amount of fluid being pumped into your muffler via the tx. Good luck...
Low Hover is offline Find More Posts by Low Hover
Sold Sullivan Skywriter Electronic Smoke System moparherb Aircraft - Fuel - Airplanes (FS/W) 3 Jan 26, 2013 07:04 PM
Found Sullivan Skywriter Smoke PumpSystem hurleycycle Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 11, 2013 06:38 PM
Sold Sullivan Skywriter 753 Smoke Pump w/ Extras StrangeGager Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jul 03, 2006 12:43 PM
Sullivan Skywriter flybymonty Giant Scale Airplanes 2 Jul 06, 2004 06:32 AM
For Sale- New...sullivan Skywriter Smoke System mikekosatka Aircraft - Fuel - Airplanes (FS/W) 2 Jun 11, 2004 08:21 AM
