Old Nov 09, 2014, 10:41 AM
adamrx7 is offline
Find More Posts by adamrx7
Joined Nov 2014
Yes stock for now, no label.(If your talking to me)
adamrx7 is offline Find More Posts by adamrx7
Old Nov 11, 2014, 10:18 AM
adamrx7 is offline
Joined Nov 2014
So I made some changes. New lighter tail fins. (old where 3.6 grams with adjustment screws new are 1 gram). I also moved the cooling system pickup tube to under the boat. With it in the back near the rudder it was causing a obstruction. She runs better now. And I can tell the rear of the boat sits higher.
Old Nov 11, 2014, 10:20 AM
adamrx7 is offline
Joined Nov 2014
I still think the rudder is in the way of the prop performing at its best. How has moving it over worked for those that have done it?
Old Feb 03, 2015, 12:20 PM
Ondahelipad is offline
Find More Posts by Ondahelipad
Ondahelipad's Avatar
United States, FL, Summerfield
Joined May 2014
Final Mod Configuration
See my post #680.
Here's my final configuration. Custom solid brass shaft.
Battery is best fit, weight and best C rated power from HK.
Great upgraded performance!
Small cooling tube part aft of coupler is a shaft leak stopper. It is secure with tie strap.
Ondahelipad is offline Find More Posts by Ondahelipad
Old Feb 04, 2015, 08:42 PM
Joined May 2014
Question
Answered in PM
Old Feb 05, 2015, 01:09 AM
Jamesd848 is online now
Find More Posts by Jamesd848
It didn't cost thaaaat much
United States, CA, SF
Joined Oct 2014
So I was a complete idiot about a year ago and ran my boat in salt water. Over time everything corroded away, over the proccess of about 6 months. Now, I need to get replacements. I probably will just grab all new electronics. I was wondering if it would be worth it to grab a different motor and throw that in, in addition to getting the ft007 esc/rx combo circuit, and I will take a look but I might need a new servo too. I have I think three stock batteries for this boat, what would the run time and speed be with a different motor be.
Jamesd848 is online now Find More Posts by Jamesd848
Old Feb 05, 2015, 09:28 AM
Joined May 2014
After saltwater ops and severe corrosion, go for new motor, the ft007 esc/rx combo circuit, the servo, and new flex shaft.
I used the Venom Fireball Micro 370P. Inexpensive & excellent performance.
Not water cooled..I don't believe water cool is good investment in FT007. I use a cheap heat sink. You can fit it easy on the motor and in the motor mount. See my posts #680 and 694. Check the battery I use..it's a good one and has good run time.
However, when you look at price for all, strongly consider buying a whole new boat. Stay out of saltwater.
Old Feb 06, 2015, 08:33 PM
Dennis Manning is offline
Find More Posts by Dennis Manning
RcBoater
Joined Feb 2014
timing of micro motors
Dennis Manning is offline Find More Posts by Dennis Manning
Last edited by Dennis Manning; Feb 07, 2015 at 04:57 AM. Reason: Subject not related
Old Feb 07, 2015, 08:23 PM
Joined May 2014
Originally Posted by Dennis Manning View Post
Answered in PM by high techy member.
Johnson assembly might off set it.
Old Feb 08, 2015, 08:32 AM
RcBoater
Joined Feb 2014
Good.
Old Apr 24, 2015, 11:50 PM
Panhead5496 is offline
Find More Posts by Panhead5496
Panhead5496's Avatar
United States, GA, Athens
Joined Nov 2014
Hey all.
I have the double horse 7009 boat, which seems to be very similar to this boat.
I want to upgrade it to brushless. I'm not overly concerned with the price(yes I know it might be cheaper to just buy a better boat-I have the atomik barbwire-but I have a somewhat sentimental attachment to this boat lol). What is the best way to do this brushless upgrade?
Panhead5496 is offline Find More Posts by Panhead5496
Question Need vital stats on Zoom w/ Himax 4200 8t vs. 9t Fishstyx Mini Helis 8 Sep 06, 2004 10:29 AM
Here's a vital controller question........ HankF Kontronik 2 Jul 21, 2004 04:38 AM
Here's a vital controller question.... HankF Castle Creations 1 Jul 20, 2004 02:53 PM
Formosa vitals? dstrout Parkflyers 2 Mar 17, 2004 12:53 PM
Organic vitals Janusz Jawien Electric Sailplanes 6 Sep 08, 2002 11:11 AM
