Old Feb 13, 2013, 12:57 AM
SmokeDogg is offline
Find More Posts by SmokeDogg
"Fly Low, Fly Fast, Turn Left"
SmokeDogg's Avatar
United States, CA, Red Bluff
Joined Jul 2009
Build Log
Custom E-Flite P-51b YS-110s Racer
So my buddy Jim and I are building us another race plane. We are using the E-Flite P-51b fuse as our base and working out from there...
First thing we noticed is how well built the tail feathers are, yet the vertical may have to be enlarged some so she tracks good at high speeds. We did find that the slots in the elevator halves for the hinges needed to be grooved back more so the hinge points were correct.
We are going to run the stock cowl however we are changing the mounting points as the canopy hatch will be glued and glassed to the fuse. So the hidden screws are out...
So after skinning the fuse it looks really nice I must say. Will look sweet all glassed up.
We started work on the firewall which will need a lot of reinforcement to hold the YS-110s. I may play around with some glass in between layers of ply, as I saw someone doing here on RCG.
The stock wing is too heavy and a little shy on the wing area for our rule set, so we are building a new sleek wing for her. The foam cores are cut out and about ready to be sheeted.
SmokeDogg is offline Find More Posts by SmokeDogg
Old Feb 15, 2013, 07:35 PM
TripleW is offline
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Nice!
How much wing do you need?
TripleW is offline Find More Posts by TripleW
Old Feb 16, 2013, 01:36 AM
SmokeDogg's Avatar
Joined Jul 2009
We need 515sq in at a minimum. Will be around 535 by my guess right now.
Old Feb 16, 2013, 06:38 PM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
I believe it's 500 for our Warbird races.
Old Feb 18, 2013, 01:20 AM
SmokeDogg's Avatar
Joined Jul 2009
515 in the min for a ys-115. It may be 500 for the 110. Would have to check that...
Wanted WANT - YS-110 / YS-110s / YS-115 New or Used SmokeDogg Aircraft - Fuel - Engines and Accessories (FS/W) 2 May 14, 2013 05:30 AM
E-flite P-51B Mustang nitro-dawg Non R/C Items (FS/W) 15 Feb 26, 2013 03:57 PM
Sold E-flite P-51B Mustang nitro-dawg Aircraft - Electric - Airplanes (FS/W) 8 Feb 22, 2013 09:54 PM
Sold NIB E-flite P-51B lmpbpd Aircraft - Electric - Airplanes (FS/W) 8 Feb 08, 2013 11:14 AM
Sold E-flite p-51B custom built with every option H to the B Aircraft - Electric - Airplanes (FS/W) 8 Jul 15, 2011 12:15 PM
