Old Dec 05, 2012, 08:32 PM
Oryon is offline
Find More Posts by Oryon
United States, OH, Cincinnati
Joined Mar 2008
Foam cutting service
Anyone know of a service that will cut a solid foam fuselage for you? I can cut wings, but the fuse is going to be a pain. I am wanting to create a mold for an all composite 120mm fan size F-100. I already have the 3d model, just need the fuselage cut.....I have no problem gluing togehter sections and doing final shaping if needed, but I am having a rough time figuring out how to hotwire it as a starting point.. I tried breaking it onto secitons, but this leaves an unscale outline, due to th curvature of the fuselage....any suggestions?
Oryon is offline Find More Posts by Oryon
Old Dec 05, 2012, 09:01 PM
BillO is offline
Find More Posts by BillO
Firecracker!
BillO's Avatar
San Francisco & Santa Cruz
What length sections did you use? Lots of people have been using the section method lately in this forum and it handles curved fuses very well. Check out the SU-25 Frogfoot and the Chimera builds (among others) for details. Sections range from 1" to 3" in length. If you have a 3D model, you have everything you need.
BillO is offline Find More Posts by BillO
Old Dec 05, 2012, 09:06 PM
Oryon is offline
Joined Mar 2008
about 8 inch sections.. guess I need to section it off more... its a fairly large airframe, didnt want to have to do that many sections, but if I have to I will
Old Dec 05, 2012, 09:23 PM
BillO is offline
Firecracker!
BillO's Avatar
Actually the number of sections and not the size is the important thing. With a larger airframe, the sections will of course be longer than a smaller one. By coincidence I'm working on an F-100 too, mine is for 90mm though. What are you using for CAD? I'm using Sketchup.
Oryon is offline
Joined Mar 2008
autocad inventor
Old Dec 05, 2012, 09:27 PM
BillO is offline
Firecracker!
BillO's Avatar
Darn! I guess I have to keep plugging away then...
Old Dec 05, 2012, 09:38 PM
Oryon is offline
Joined Mar 2008
whats your overall length for the 90mm?
Old Dec 05, 2012, 11:13 PM
BillO is offline
Firecracker!
BillO's Avatar
Fuse is 62" and span is 52".
Old Dec 07, 2012, 02:00 PM
D_FAST is online now
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
If there is a lot of contours and tight curves use smaller sections.
There is no reason not to use different spacing per your liking in the same model. Mix and match for detail as needed.
Might depend on tooling as well. I can only cut up to 5" straight and 3 1/2" at a 45 degrees with my hand tool. And
Scroll Saw
D_FAST is online now Find More Posts by D_FAST
Old Dec 07, 2012, 02:16 PM
Oryon is offline
Joined Mar 2008
I've decided to buy/build a CNC router... since I have intentions of doing many scratch builds after this one
Old Dec 07, 2012, 02:41 PM
PhilLin is offline
Find More Posts by PhilLin
Oshkosh, WI
Joined Nov 2002
Klaus showed a cnc hot wire cutter with two heads. This was in his Saab 35 Darken thread. Seems like a very nice way to go from CAD directly to parts. If you're building lots of prototypes, might be the way to go.
Cheers,
Phil
PhilLin is offline Find More Posts by PhilLin
Old Dec 07, 2012, 04:53 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Originally Posted by BillO View Post
By coincidence I'm working on an F-100 too, mine is for 90mm though. .
What is estimated weight? Also, have you decided on what fan/motor combo you will use?
While I'm waiting to finish my F-86F, thought I'd build sport foamy about the same size for my JetFan 90. Just like to see what others are using.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Dec 07, 2012, 09:33 PM
BillO is offline
Firecracker!
BillO's Avatar
I haven't done a proper weight estimate, but I'm hoping about 5 lbs for the airframe and 5 lbs for the gear for a total of 10-12 lbs.
As for fan/motor, something nice like a Jetfan or Stumax. I'm thinking 10s so that will drive the motor choice. Nothing definite yet though. I was hoping to see how yours turns out!
Old Dec 07, 2012, 10:39 PM
Joined Dec 2008
BillO
I have been doing a little comparison shopping if you will. What motor/fan combo's give you what kind of perfomance. What stuck me in this video was the sound, but also his set-up.
http://www.rcgroups.com/forums/showp...&postcount=545
I PM'd Emile for other specs not in post. Here's what he got.
I'm using 1,5 year old Turnigy Nanotech 4s5000 (45c/90c) 2x.
This setup pulls about 110amps at 3,250KW.
It's hard to say how much thrust it generates.
Inflight the Jetfan produces visibly more then shown in the graphs of ejets. I experience similar in my Habu
This should push your F-100 right along!
Food for thought. Good luck on your build.
Old Dec 10, 2012, 10:47 PM
Wilfor is offline
Find More Posts by Wilfor
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
check out this foam cutter http://www.rcgroups.com/forums/showthread.php?t=1618001
Wilfor is offline Find More Posts by Wilfor
Question Foam Cutting Service? CRCJA Electric Ducted Fan Jet Talk 16 Aug 30, 2012 09:20 AM
Computer Foam Core Cutting Service fatboywings Slope 6 Jan 11, 2003 08:26 PM
Want to find CNC foam cutting service zbrubaker Foamies (Kits) 1 Nov 04, 2002 09:34 AM
Foam Cutting Service : Where Could I Find? CESARNOGUEIRA Foamies (Kits) 13 Nov 27, 2001 05:22 PM
