Old Oct 16, 2012, 08:53 AM
drakison is offline
Find More Posts by drakison
United States, SD, Sioux Falls
Joined Aug 2012
Help!
EFlite Power 52 prop adapter too short!
I am converting my Hangar 9 P-51 to electric, and I really would like to use the red spinner for the scale look. Only one problem, the prop adapter that came with the Power 52 is too short if I use the spinner.
Are there other common adapters used out there that I am unaware of? I've searched quite a bit, but it doesn't seem that there is any one brand that stands out.
Also, bolt on vs collet style adapters....which is better for a 40 size setup with about 1000 watts?
Thanks in advance!
drakison is offline Find More Posts by drakison
Old Oct 16, 2012, 11:10 AM
Harry H is offline
Find More Posts by Harry H
Harry H's Avatar
Los Angeles
Joined Oct 2010
Not sure what you mean by too short. Pic would help. As for the collet vs bolt on. I have been using a collet on a Eflte 60 for some time now with no problems but think the bolt on is a better way to go. The only problem with a collet is getting the right torque and not mess up the threads. I have 2 other planes with the 60 and use bolt on adaptors. Much easier to change out a prop.
Harry
Harry H is offline Find More Posts by Harry H
Old Oct 16, 2012, 01:55 PM
drakison is offline
Joined Aug 2012
Well as far as too short, When I place the backplate of the spinner on the collet, then the apc prop, there are not enough threads left for the adapter threaded cone. I need about another 3/8' to get enough threads. I did find this though just this afternoon....and I think it will work.
http://www.rcdude.com/servlet/the-97...ng-Prop/Detail
What's the watts on your model running that power 60 and what prop are you swinging?
Old Oct 16, 2012, 02:04 PM
Harry H is offline
Harry H's Avatar
Los Angeles
Joined Oct 2010
I would have to look it up to make sure but I think it is pulling 1850W with a 16x10 APC. I think I understand your problem. I am using an Eflite spinner that uses the collet.
Harry
Old Oct 16, 2012, 02:08 PM
drakison is offline
Joined Aug 2012
Ahh, a collet on mine should be fine then....as I am going to be pulling about 1200 watts with a 12X8 prop on a 6-7 lb 40 sized model.
Thanks for your help!
Question Is this too much vibration from the prop adapter? ClevelandBaller Electric Plane Talk 20 Jul 21, 2012 03:37 AM
Question Eflite Power 25 Prop Adapter Threads? maguro Power Systems 2 Nov 02, 2010 10:13 AM
Sold eflite power 15 with prop adapter and spinner fnlrun Aircraft - Electric - Power Systems (FS/W) 3 Feb 13, 2010 09:20 AM
For Sale Eflite power 60 with AXI prop adapter M Carr Aircraft - Electric - Power Systems (FS/W) 2 Aug 24, 2008 06:49 AM
himax prop adapter too short jhas Power Systems 4 Jan 20, 2005 01:04 AM
