Old May 11, 2012, 09:28 AM
sahil80 is offline
Find More Posts by sahil80
United States, VA, Sterling
Joined Mar 2012
Question
How to install 6x4e prop?
Hey Folks - I am sorry to fry some of you with such a question but I cannot seem to understand how to install this APC6x4e prop on my HawkSky's stock motor. This prop looks too big for my motor and although it came with two sizing options none fits correctly.
I have attached pics of my stock 5x5 prop and the new APC-6x4e prop - Any tips on this?
sahil80 is offline Find More Posts by sahil80
Old May 11, 2012, 10:39 AM
dedStik is offline
Find More Posts by dedStik
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
Looks like you were shorted some adapters. Your LHS may have some more.
I realize these are not APC, but APC-like. It is just to illustrate what sizing rings yours should have come with.
http://www.hobbyking.com/hobbyking/s..._75_2_pc_.html
dedStik is offline Find More Posts by dedStik
Old May 11, 2012, 02:55 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
To fit the APC type props you need a 'prop adapter'. If you do a Google search on 'prop adapter' you should get plenty of information and pictures of what they look like.
Basically the adapter fits on the motor's shaft, and gives a larger shaft diameter for the propeller, which is then held on the adapter with a nut. The 'prop adapter ring', also in your picture, is to ensure the prop is a good fit on the adapter shaft.
You need to know the motor's shaft diameter to buy the correct adapter.
eflightray is offline Find More Posts by eflightray
Old May 11, 2012, 03:14 PM
M Ashmore is offline
Find More Posts by M Ashmore
Average User
M Ashmore's Avatar
Bakersfield, California
Joined Aug 2003
Like these......
http://www.headsuprc.com/servlet/the...ers/Categories
Again, measure your motor shaft diameter to get the correct adapter.
M Ashmore is offline Find More Posts by M Ashmore
Old May 11, 2012, 04:55 PM
sahil80 is offline
Joined Mar 2012
Thank you guys - I was able to find an adapter in my local LHS -
I did a dry run and ran the motor at 80%-100% throttle for 30/35 seconds and its temperature was hot. Not finger burning hot but considerable hot - Battery was normal and I couldn't feel temp of ESC as it is somewhere inside the fuselage.
I hope to go out and make a flight to see how well it runs
Discussion How to Properly Install Counter-Rotating Props on a Multi Motor Aircraft WAGliderGuy Power Systems 29 Feb 11, 2012 11:23 PM
Sold MicroDAN 2505 "Custom" 2535Kv motor + APC 6x4E prop = $40 shipped shawn595 Aircraft - Electric - Power Systems (FS/W) 0 Jul 25, 2010 04:44 PM
Discussion 6x4E prop - TGS vs APC ? SpookiePower Power Systems 5 May 18, 2010 06:24 PM
Discussion How to install the prop - 6x4E on EZ* ? SpookiePower Beginner Training Area (Aircraft-Electric) 3 Oct 24, 2009 03:39 PM
Discussion Stock Permax 6v and APC 6x4e prop teamgs Foamies (Kits) 0 Apr 11, 2008 11:45 AM
