Old Feb 27, 2011, 10:05 AM
FoamieFlier is offline
Find More Posts by FoamieFlier
FoamieFlier's Avatar
Joined Dec 2010
I'm giving up on my PZ ME-109
I started off flying in spring 2008 with Real Flight and a HZ Super Cub, then moved on to a PZ brushed P-51 and flew that till it was more tape than original parts, then a PZ Corsair which I have only crashed once and love to fly (my favorite plane so far), then a PZ Wildcat (about a dozen or so flights on that, only 1 crash, had my elevator reversed on first flight).
So I bought a PZ ME-109 and two flights and two catastophic crashes later, I am giving up, salvaging the electronics, and moving on from that plane. First flight, it was very touchy and I lost orientation and nose dived it straight into the ground. Buy a new fuselage, rebuild it, enlarge the wingtip yellow paint, add yellow paint to the wing under the fuselage, and spend a good amount of time setting the D/R and expo, and centering the control surfaces. Go out this morning, hand launch, and before I could get my hands back onto the controls, the plane climbs, rolls to the left, and smashes into the ground.
Makes me wonder about buying the FMS ME-109f coming out this summer. I don't know if it is beyond my current skill level, the flight characteristics of the ME-109, the flight characteristics of PZ's ME-109, or a combination of all 3.
FoamieFlier is offline Find More Posts by FoamieFlier
Old Feb 27, 2011, 11:04 AM
capadotia is offline
Find More Posts by capadotia
Joined Jun 2008
Yeah, this plane can be a handful. It has terrible ground handling and if you are too slow and go full throttle it has a nasty torque roll to the left. The torque roll has got me on a couple of occasions but now I am used to it. On a hand launch give it a good strong throw with the throttle at 3/4 and you should be ok.
Once you get the plane flying and up to speed it flies great but it is not for everyone. My 109 actually came from my brother who traded for my T-28 because he hated it. I put a bigger Turnigy motor in it running 900 kv a 60amp speed controller and eflite electric retacts and I really like it now. But landings and takeoff always present a challenge which I like but again is not for everyone.
capadotia is offline Find More Posts by capadotia
Old Feb 27, 2011, 11:12 AM
shultz is offline
Find More Posts by shultz
United States, NV, North Las Vegas
Joined Sep 2009
I think once set up correctly(CG is CRITICAL as are throws) it's a nice flying plane... it is a real to land and take offs can be a wild ride as well... I finally gave up on the wheels and now hand launch/belly land... MUCH easier
For hand launch I use about half throttle on my power 15 turning the stock 3 blade prop...a gentle toss and she flies away cleanly... any more throttle and you will be in for a wild ride due to prop torque
The real 109 killed LOT's of pilot's on take off and landing... the PZ version seems to be the same... set up right...keeping in mind it's a war bird and flying it accordingly... it's a real pussy cat in the air.
shultz is offline Find More Posts by shultz
Old Feb 27, 2011, 11:44 AM
Joined Dec 2010
Torque Roll
That was my first thought after I crashed it, that I had to much throttle, and it Torque Rolled. Then I thought that I should have read through the PZ ME-109 threads last night to see how most people handle the hand launch. Then I thought God is punishing me for skipping church to fly a Nazi airplane.....
Old Feb 27, 2011, 01:13 PM
Ah Clem is offline
Find More Posts by Ah Clem
Team Compass/KBDD Team Pilot
Ah Clem's Avatar
Joined Mar 2005
"Yeah, this plane can be a handful. It has terrible ground handling and if you are too slow and go full throttle it has a nasty torque roll to the left."
I respectfully disagree.
Roll the power on smoothly at takeoff (I don't think I have ever used full throttle at take off), be ready or right rudder, make sure you have enough air speed-it will rise off straight and not drop the left wing.
On landing, don't slow it down too much and be ready on left rudder as the tail drops.
It will tip stall if you slow it down too much (I have found out the hard way-but this was my error). Never punch the throttle when going too slow (found that one out too). Apply/reduce power smoothly and there is no problem.
I am a helicopter flyer and a lousy airplane flyer, by the way.
Ah Clem is offline Find More Posts by Ah Clem
Old Mar 02, 2011, 03:52 PM
GradyLee is online now
Find More Posts by GradyLee
Parkstormer!
Raleigh, NC
Joined Jan 2010
I struggled with mine at first, too, precisely because of the torque roll. I learned to tame it, though. When using gear, I apply throttle gradually and "feed in" right rudder, and let it get some speed up before giving it any significant up elevator. When hand-launching I use about 75% throttle and apply right rudder all the way through the toss, until the plane's up and tracking straight, then let go of the right rudder. Now, it's one of my favorites!
GradyLee is online now Find More Posts by GradyLee
Old Mar 02, 2011, 05:03 PM
Bullit is offline
Find More Posts by Bullit
Joined Apr 2005
i have a power 25 in mine, 3/4 throttle and no toss needed, let it go and away it goes straight and level. the easiest plane i have to hand launch too.
Bullit is offline Find More Posts by Bullit
Old Mar 02, 2011, 05:48 PM
southernmd_man is online now
Find More Posts by southernmd_man
Gravity's a harsh Mistress....
southernmd_man's Avatar
United States, MD, Lusby
Joined Jan 2007
From the sound of it, you're expecting the plane to fly it's self. The Corsair is pretty much a bent wing glider, and almost flys it's self. The 109 on the other hand has to be flown, a first for the PZ line. I've had all the PZ planes, and the 109 is the first that needs you to be a pilot from take off to landing.
southernmd_man is online now Find More Posts by southernmd_man
Old Mar 02, 2011, 07:25 PM
Fox-composites is offline
Find More Posts by Fox-composites
Thailand
Joined Aug 2010
I fly a Spitfire model and was reading the full size pilots notes.
They used to hold right rudder and right aileron for take off.
I tried this and it works great.
I guess it takes the weight off the left wheel a bit and helps to keep it straight.
You obviously need to get the right rudder and right aileron off once airborne but it really helps the tracking down the runway during take off.
Jim
Fox-composites is offline Find More Posts by Fox-composites
Old Mar 03, 2011, 08:02 PM
kahloq is offline
Find More Posts by kahloq
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
I hate handlaunching...too many flubs LOL.
My PZ 109 still has gear and its not too bad to get airborne. I also have a power 25 in it running on 4s 2200 with a 12x10 prop.
Flaps seem to work somewhat ok for slowing it down, but Im gonna add the inner split flap portions soon.
kahloq is offline Find More Posts by kahloq
Old Mar 04, 2011, 04:55 AM
James321 is offline
Find More Posts by James321
James321's Avatar
UK
Joined Nov 2009
The PZ BF-109 isn't for a beginner at all and I think the title "Park Flyer" makes people think it's a nice little plane for a beginner to take down to the park on a Sunday afternoon.
They will then become very disheartened when it all ends in $200 tears and a bag of foam parts.
Parkzone should really apply a difficulty scale to their aircraft so it's quite clear just what you're purchasing and don't end up exactly as the original poster of this thread has.
Don't be disheartened, the 109 is notoriously difficult to launch, in fact there were more 109's lost in the Second World War through ground handling incidents than actually shot down!
Keep trying with it as it is a lovely plane to fly, follow these easy steps:
1. make sure all the controls work correctly
2. use minimum rates
3. 30% expo on all controls!
4. Make sure the C of G is forward, you want it to balance slightly nose down
5. hand launch with 3/4 throttle and be ready to give some right rudder
6. better still, get someone else to hand launch for you.
Once used to flying it, the wheels can go back on and practice practice practice taxying around, build up the speed and let the tail fly, keep practicing until it becomes natural to steer the plane with the tail flying.
Then its just a case of a little more throttle and she's away.
Please don't give up.
James321 is offline Find More Posts by James321
Old Mar 04, 2011, 09:59 AM
dude_109 is offline
Find More Posts by dude_109
dude_109's Avatar
Houston, TX
I thought my 109 is the easiest to hand launch. Its also the biggest/heaviest in my 10+ hangar of hand launch planes. 3/4 or so throttle on launch with stock set up and 2200mah lipo and it just floats away. I tend to like aft c.g. so it launch/land much slower.
dude_109 is offline Find More Posts by dude_109
Old Mar 04, 2011, 10:11 AM
mdugas is offline
Find More Posts by mdugas
Joined Aug 2003
hi,several flight sims have the pz109 and others parzkone ac,i have it on the
flying model simulater [free],not an exact macth in way it flies but good
enough for practice
mdugas is offline Find More Posts by mdugas
Old Mar 04, 2011, 10:48 AM
James321 is offline
James321's Avatar
UK
Joined Nov 2009
It will be much more sensitive in pitch with an aft CofG so probably not so good for someone struggling to fly this one.
Keep it forward and keep it safe.
Old Mar 04, 2011, 11:53 AM
dude_109 is offline
dude_109's Avatar
Houston, TX
Yes, pitch will be more sensitive but the plane can fly slower w/o fear of stalling. Some expo on the elevator channel can counter the pitch twitchiness. He's got more than enough experience on flying so slower flight capability will allow less throttle on toss and less torque roll. That's how I see it. Whatever work for folks.
Build Log SCALING UP THE Pz Bf-109 G6 Hartmann kusunokimasahige Electric Warbirds 45 May 22, 2013 02:38 PM
Discussion Follow up on giving the SD-10G a second chance Mr. Wiz Radios 8 Feb 21, 2011 09:49 PM
Discussion giving it up abaser Beginner Training Area (Fuel) 19 Oct 01, 2010 12:54 PM
Help! Giving Up on My MSR! netsurfr Micro Helis 19 Sep 26, 2009 03:19 PM
Discussion I'm Giving Up On HS-55's Murocflyer Radios 37 Jul 09, 2009 02:08 PM
