Old Feb 21, 2011, 07:18 AM
serbcccc3 is offline
Find More Posts by serbcccc3
USA, TX, Houston
Joined Jan 2011
Help!
10mm square CF Arm Question
___
serbcccc3 is offline Find More Posts by serbcccc3
Old Feb 21, 2011, 12:28 PM
USA, TX, Houston
Joined Jan 2011
Ok, so ive used 8mm square CF tubing with wood inserts, but never used the 10mm CF square tubing. I havent been able to find any 8mm square so i bought some 10mm square cf. My question is this.
With the 8mm square cf tube with wood inserts, i have a pretty strong arm. For the 10mm square, I cant find any local hobby shop with square wood dowels that are of proper size to fit inside the 10mm square tubing (has an 8mm inside diameter)
Does anyone have any tips for strengthening the 10mm square?
Do i really need to strengthen the 10mm square? Or do you think it will be ok as is.
I plan on using about 500mm for each arm, with the motors mounted at about 333mm from dead center (extra arm for protection as im kind of a crappy pilot still!)
Thanks!
Marko
Old Feb 21, 2011, 03:35 PM
SargeNZ is offline
Find More Posts by SargeNZ
Dizzying Heights
SargeNZ's Avatar
New Zealand, Southland, Invercargill
Joined Feb 2003
You could always slide your 8mm square section into the 10mm.
SargeNZ is offline Find More Posts by SargeNZ
Idea 10mm aluminum square tubes group buy bat Multirotor Talk 37 Apr 11, 2013 12:52 PM
Discussion 10mm X 10mm X 900mm basswood square dowels HappyKillmore Hot Online Deals 6 Nov 01, 2009 02:53 AM
Wanted Thrust Mod for 10MM Square Tubing Murocflyer Aircraft - General - Miscellaneous (FS/W) 10 Feb 06, 2008 11:06 PM
Discussion nippy black 10mm square mount Plumber Power Systems 3 Jan 07, 2006 11:47 PM
Looking for 10mm OD cf tube Salmon-Run Sailboats 2 Sep 15, 2004 09:12 PM
