Old Dec 01, 2010, 01:39 PM
techman28 is offline
Find More Posts by techman28
Joined Nov 2010
How to measure voltage on an Eflite/Parkzone 1 cell lipo?
I am looking to find out if there is any way (at least any relatively easy way) to measure the voltage of an Eflite/Parkzone 1cell lipo? The type of lipos I am talking about are the ones that are for the Eflite mSR and mCX/2 as well as most or all of the Parkzone Ultra Micro planes.
I would like to be able to check the voltage after flying to see what its at so I know whether I can fly a little longer or if I should stop sooner. The obvious problem with these lipos are the very small connector it uses. Has anyone figured out a way to do it or have any ideas? Thanks
techman28 is offline Find More Posts by techman28
Old Dec 01, 2010, 01:44 PM
chrisf testpilot is offline
Find More Posts by chrisf testpilot
You can call me FANBOY!
Goodlettsville, TN
Joined Sep 2006
A dvm would be the easiest way. Radio Shack has some really inexpensive pocket sized ones.
chrisf testpilot is offline Find More Posts by chrisf testpilot
Old Dec 01, 2010, 02:05 PM
Joined Nov 2010
If I use a dvm, do you know which part of the connector I should put the red test lead on and which I should put the black test lead on? Thanks again.
Old Dec 01, 2010, 02:15 PM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
but the contacts are so small and so close together that it is a bear to use DVM probes without shorting the cell.
The safet way to check the voltage using a DVM would be to purchase an extension,cut it into and use the female end (the one the battery pugs into) with te exposed ends stripped and seperated or better yet with a suitable connector on it. I use a DVM with a spare charger out put oi to check my oyer LiPolys ( 4mm bullets to Deans Ultra). A male Deans on the modified (cut) extension works great.
HK sells the Micro extensions.
Back when I ordered mine
Hobby King has some JST- XH extensions listed , 5 for $1.98.
One of the photos here shows part of an extension I added to my mSR
http://www.rcgroups.com/forums/showp...6&postcount=16
Charles
With a digital DVM it reall makes no difference. If the contacts(leads) are reversed then you will see a negative voltage. Try it on a battery such as a AA and see what I mean.
everydayflyer is online now Find More Posts by everydayflyer
Old Dec 01, 2010, 03:35 PM
Dave H. is online now
Find More Posts by Dave H.
Joined Feb 2008
And an analog DVM wouldn't be a DVM.
Dave H. is online now Find More Posts by Dave H.
Old Dec 01, 2010, 03:51 PM
Goodlettsville, TN
Joined Sep 2006
Thanks Charles, I looked at a couple pics but couldnt actually tell how close together they are and havent really handled any of these. An extension with bullets on it to plug directly in to the dvm would be the safest way to do it.
Old Dec 01, 2010, 05:39 PM
Southern Pride
The D stands for digital so no.
http://en.wikipedia.org/wiki/Voltmet...tal_voltmeters
Old Dec 02, 2010, 12:13 AM
Joined Nov 2010
Would this be a good enough DVM to get? - http://www.radioshack.com/product/in...uctId=4214667#
Old Dec 02, 2010, 12:21 AM
Goodlettsville, TN
Joined Sep 2006
That would should be fine for what you are doing.
Old Dec 17, 2010, 11:36 PM
Joined Nov 2010
I just bought a new Digital Multimeter but I've never really used one before. What setting should I put it at to read the voltage of a 1 cell lipo? Also which "input" should I put the red probe in for my purposes (as you can see in the picture, there are two red probe options) Here is the pic of the one I bought.
Old Dec 18, 2010, 03:51 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
It should be about 4V which is more than 2V and less than 20V so set the meter to 20 DCV (volts). Use the RH connector marked V for volts.
Steve
slipstick is offline Find More Posts by slipstick
Old Dec 18, 2010, 10:27 AM
Joined Nov 2010
Steve
Ok, thanks for the info.
Old Dec 18, 2010, 10:35 AM
Southern Pride
Goggle is your friend. It took me less than 1 minute to find this
http://www.doctronics.co.uk/meter.htm#digital
Old Dec 18, 2010, 01:01 PM
KC is offline
KC
Find More Posts by KC
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
I found this picuture in the RTF forum to help you measure the lipo's voltage safely.
Open up the charger like the picture below. (remove the 4 screws under the rubber feet.)
After placing the lipo in the charger slot, place the red probe of your DVM on the red wire connection point and the black probe on the black wire connection point. Make sure you do not let the red/black probes touch each other while measure the voltage.
Description:
KC
KC is offline Find More Posts by KC
Old Mar 26, 2011, 09:08 AM
Schermvlieger is offline
Find More Posts by Schermvlieger
I love HAM
Joined Nov 2005
Attachment 3668677
KC
Hi guys,
My HobbyZone/ParkZone charger is overcharging to at least 4.4V
Luckily I took the battery out before it was damaged.
I opened up the charger and measured resistance on the legs of the pot to compare the values with the picture attached. The readings are:
1854mOhm instead of the 1208mOhm value
141mOhm instead of the 587mOhm value
They don't add up to the same values (1995 versus 1795) and I am not sure what can be said from these values, but I am hoping that with an adjustment of the pot on my charger I can stop it from destroying my batteries.
If anyone can shed any light on this that would be great!
Sandor
Schermvlieger is offline Find More Posts by Schermvlieger
Discussion Using a cell checker to measure a 1 cell battery? xraydoc Batteries and Chargers 9 Sep 05, 2010 08:52 AM
Discussion Measure Individual Cell Voltage (LIPO) malekia Batteries and Chargers 9 Mar 08, 2010 07:45 PM
Discussion How to measure cell voltage? jblparisi Batteries and Chargers 3 Aug 19, 2008 09:03 PM
Discussion Can i use an 3 cell lipo on my futaba 9chp super? Whats max voltage it can take? djdaveq Radios 14 Jul 14, 2008 09:36 PM
Reducing the output voltage on a 1 cell lipo SoulTag Batteries and Chargers 15 Jun 12, 2005 07:20 PM
