Old May 19, 2008, 03:08 PM
Is life for real?
pkboo's Avatar
Almere The Netherlands
Joined Sep 2006
Question
V-tail mix on sub
Now that I'm moving into a next phase yeah I'm trying out the Revell 1/72 Type VII and going for more than two channels, I've got a question! I've searched, just to much hits to get a real objective "that's it idea" and put it on radios but haven't got a reply yet, maybe it's because I put it with airplane guys, dunno Here goes....I know that a v-tail mix not only allows you to turn your rudder, possibly you can mix the elevators as well as your motors to make tighter turns but does it also hold in that on straight runs it synchronizes motor speed? Or is this just asking to much and wishful thinking? The question rises out of the fact that I've got two slightly different motors to put into the sub, two mabuchi type RF365 SA and SH taken out of hairdryers. If somebody could explain the v-tail thing in regard to this I'ld be very thankful, appreciative, obliged and no I'm not willing to give money Boo
pkboo is offline Find More Posts by pkboo
Old May 19, 2008, 05:01 PM
steveciambrone's Avatar
United States, CA, Santa Clarita
Joined Dec 2005
For the Type VII since it has a convential tail (rudder and stern planes) the V tail mixing will not work.
You really want to use matched motors since a difference in RPM will cause the boat to steer to one side causing it to not run straight.
Steve
steveciambrone is offline Find More Posts by steveciambrone
Old May 19, 2008, 05:03 PM
FROM THE MIND OF A MADMAN
gpzy's Avatar
Joined Apr 2007
Check out www.subpirates.com there are plenty of sub gurus over there.
gpzy is offline Find More Posts by gpzy
Old May 19, 2008, 05:16 PM
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Unless you are using two ESC, there will be no way to sycncronize the motors.
Twin throttles on the transmitter become problematic. In that you end up synchronizing the motors manual. Even then, fiddling around with trims and sub-trims on the transmitter won't sync up the motors if it requires running one up faster than the other to get a match.
For rudder and propeller speeds people have been succesful at using mixers.
I'm not sure when it comes to mixing two ESC...
Umi_Ryuzuki is online now Find More Posts by Umi_Ryuzuki
Old May 20, 2008, 03:33 PM
Is life for real?
pkboo's Avatar
Joined Sep 2006
Thanx!
Thanks Steve I thought as much but then again we tend to say to ourselves "oohh it won't be that obvious!" until we see it of course I thought that as in boats if you have two ESC you could use the v-tail thing. Having in fact 3D with a sub you could let it handle as a plane, or so I thought
gpzy that's my next stop for the question if nothing comes out here! I've checked them already out in regard to a lot of things of a sub, stubbornly enough I tend to do things more my way using what I've seen and read and of course that what could be explained logically.......but then again I find that this place here is more friendly, so I try it here first
Umi, but but I will be installing two ESC's Are you telling me that the posibility is there? OK I did think of the trim thing but I thought more that a certain type of radio could/would do the job like kinda auto
Thanx so far you guys Boo
Old May 20, 2008, 06:56 PM
United States, CA, Hayward
Joined Feb 2006
Pkboo Set your radio up in elevon mode and put one motor on elwvator and the other on aileron and it will mix ok, but as far as sync I think you are out of luck. Might look at setting the channels up in master slave with some EPA on the faster motor to compensate, should be an interesting project and you may learn some new curse words before you get it worked out.
CaptLee is offline Find More Posts by CaptLee
Twin ESCs, V-tail mix, coaxial helo IAD Micro Helis 4 Dec 17, 2002 07:53 AM
Twin ESCs, V-tail mix, what will burn? IAD Power Systems 13 Dec 11, 2002 09:16 PM
v-tail mix problems CHARLIE BRITT 7 Electric Sailplanes 11 Sep 15, 2002 06:39 AM
Flash 5 v-tail mix question. omega blood Electric Plane Talk 4 Aug 04, 2002 03:36 PM
Help w/ V-Tail Mixing on Futaba 6A & GWS R-4P Aspen Parkflyers 3 Dec 30, 2001 06:01 PM
