Old Aug 22, 2004, 02:00 PM
Joined Aug 2004
Question
Help, Somebody - J-3 Cub
Hello there.
I bought my very first J-3 Cub a couple of months ago, and all it does on ground take-offs is fly around in LEFT circles on the ground!
After numerous frustrating ground control practices, I set the base trim to the extreme right to start with, and even gave full right rudder before throttling, to try and compensate for the Cub's desire to go around in left full circles!
Nothing doing.
She just LOVES to spin around in LEFT circles.
Please can some kind soul tell me what I'm doing wrong?
I'm afraid to hand-launch it because I think it'll go spinning away to the left in the air!
Thanks and Regards
Amin
Amin1234 is offline Find More Posts by Amin1234
Old Aug 22, 2004, 02:10 PM
Lookin' Good. Real Good.
larsy87's Avatar
London, Canada
Joined Aug 2002
Is your left wheel spinning freely?
Also, it is most likely torque. Try throttling up slowly instead of firewalling it.
Cam
larsy87 is offline Find More Posts by larsy87
Old Aug 22, 2004, 02:11 PM
Specialist in Crashing
UK, Loughborough
Joined Jan 2004
Have you checked the wheels are straight on the plane? Also when you look at the plane you want it so the rudder is perfectly straight. If it isnt those 2 things check the propellor is facing directly forward. Then i would check to see if the wings are on straight and level. Dan
saitrix is offline Find More Posts by saitrix
Old Aug 22, 2004, 11:02 PM
Son House's Avatar
St. Louis Mo.
Joined May 2004
Originally Posted by Amin1234
Hello there.
Nothing doing.
Thanks and Regards
Amin
I had the same problem and it turned out to be the wheel was to loose and would rub on the landing gear wire when the the plane was on the ground. Solution!! I used some left over guide tube frome my Me-109. this fits the wire perfect. cut a section and put it on first. Then put wheel on next. Ruff up the end of the wire with some 100 grit sand paper and cut another section . drop a little bit of CA on and put the other section on. Be careful not to get any on wheel becuse it will freez up wheel!!! Hope this helps!
Son House
Son House is offline Find More Posts by Son House
Old Aug 22, 2004, 11:36 PM
Vampowered!
Vamooska's Avatar
Crestview Florida
Joined Dec 2003
Absolutely great suggestions. This problem is not serious...you were very wise to try and resolve it before you went airborne though. If these don't fix it...we will get to the bottom of it. Let us know if you need more help.
Peace
Vammy
Vamooska is offline Find More Posts by Vamooska
Rant Help, Please! - J-3 Cub Electric Amin1234 Electric Plane Talk 1 Aug 22, 2004 08:36 PM
Hobbico J-3 CUB power HELP needed CRASHED AGAIN Power Systems 1 Jun 22, 2004 11:21 PM
Hobbico J-3 CUB HELP CRASHED AGAIN Parkflyers 0 Jun 21, 2004 11:50 PM
Wattage J-3 Cub 180... Help... Pleeeease! feet-dry Beginner Training Area (Aircraft-Electric) 4 Sep 07, 2002 03:45 AM
Tail feathers help for my Pico J-3 Cub Fuse? Will Chapman Parkflyers 4 Jun 06, 2001 03:35 PM
