Old Nov 05, 2014, 12:33 PM
Joined Mar 2014
Question
Fatshark new SMA plug? Where to find
Hey guys! My fatshark SMA adapter just broke off of my transmitter and I want to replace it. Where do I find the new plugs at? I cant seem to find them anywhere.
thank you!
Kyle
Brothainchrist06 is offline Find More Posts by Brothainchrist06
Old Nov 05, 2014, 01:21 PM
Registered Noob
protocol's Avatar
Canada, ON, Toronto
Joined May 2011
Fwiw, I broke my sma connector off my 250mw, and did find a replacement locally.
The problem that I didn't notice is that the center pin pcb trace ripped off with the connector, so I had nothing to solder to, d'ohhh.
Have a close look at what's left on the board to see if it's even fixable. Those fatshark 250mw vtx seem to have a assembly flaw, the clear shrink wrap that protects the board is too tight, and puts extra stress on the connector. The spacer they use to separate the boards seems too short.
At least, that's how mine was, ymmv.
protocol is offline Find More Posts by protocol
Old Nov 05, 2014, 01:42 PM
Joined Mar 2014
Ok good to know. I'll have to go look at the radio shack here in town. Thank you.
Help! Where to find FatShark 1.3GHz VRx modules? xoxota FPV Equipment 1 Sep 23, 2014 03:52 PM
Discussion Where do you go to find out about new multi-rotors? jameslew Multirotor Talk 1 Jun 08, 2014 02:06 AM
Sold cable SMA plug to SMA jack bulkhead RA 90 RG316-D 10cm double shielded pigtail Chad2323 FPV Equipment (FS/W) 0 May 31, 2014 02:52 PM
Sold 4'' SMA plug extension with 90 degree male plug ff954 FPV Equipment (FS/W) 6 May 19, 2014 07:09 PM
Sold New 5.8GHZ RP-SMA Clover leaf antenna's Fatshark xhover FPV Equipment (FS/W) 2 Nov 20, 2013 01:03 PM
