Old Mar 18, 2014, 08:02 PM
Israel
Joined Mar 2012
RCModelReviews FPV Diversity
This thread has information (board design, components, etc.) needed to create two and three way FPV Diversity with hysteresis in a *very* low budget.
The original two way diversity design is based on RCModelReviews (check youtube) video.. The three way diversity is a new design we've added.. See details below
Questions welcome!
Edit: first tests with the diversity controller using arduino PWM through a low-pass filter look promising.
Next test once my RX5808 arrives..
Edit : First rev of the 3 way diversity controller with LM324N & 74HC4053P added. Overall component cost should still be under 2$
Edit: Another rev of the 3 way diversity controller with LM324N & 74HC4053P + 2*74AHCT1G08DBV AND gates
Edit: Original two way diversity tested & working !
Edit 5/03/14: Two FPV receiver designs added. These drastically lower the cost of adding diversity to your system.
- Rx5808 based Rx for Boscam designed by TimJC
- AWM662RX based Rx for Airwave designed/edited by GilCD85
Edit 5/11/14: Two way diversity tested & working with real video output (see vid)
Edit 5/19/14 Great news guys. The 3 way diversity board is working!
What makes it even more fun is that you can put one together in 3.7$!! (shipping of the parts included )
If you're short on cash & up to the challenge of putting this together on a proto board the cost is a staggering 72 cents (0.72$..) lol!
I received the board from OSHPark today and put it all together.
I connected the 3 RSSI inputs to my arduino and sent alternating signals to the board and looks like it's tracking well.. I'll run a real RSSI test with vid input probably later this week.
Diversity with RV low pass filter (0 min 39 sec)
FPV DIY Diversity (0 min 44 sec)
FPV Diversity Works! (0 min 44 sec)
3 Way FPV Diversity Controller Works!! (1 min 16 sec)
gilcd85 is offline Find More Posts by gilcd85
Old Mar 18, 2014, 09:04 PM
This we'll defend
Libtekguy's Avatar
United States, CA, Sacramento
Joined May 2011
Cool, I've been following his device too. I was using Multisim to model it. Seems to work.
Libtekguy is offline Find More Posts by Libtekguy
Old Mar 19, 2014, 03:50 PM
United States, OH, South Lebanon
Joined Jul 2005
Here is my go at drawing up Bruce's schematic in Eagle, and adding pin headers. Let me know if you see any issues with it.
For the board I just tossed the parts on and hit the autorouter button. You should be able to upload $1.29_DIY_Diversity_Autoroute.brd to OSHPark.com to order them.
Links to Files:
TimJC is offline Find More Posts by TimJC
Old Mar 19, 2014, 06:14 PM
Israel
Joined Mar 2012
I generally like through holes vs. pin headers. First post updated with board layout.
7.70$ for 3 boards in OSHPark
Latest blog entry: Bixler FPV into the sunset
Old Mar 20, 2014, 07:20 AM
rsequeira's Avatar
Joined Oct 2012
very nice. i will try to build this diversity too. the capacitor is 0.1 microF ou miliF? in the bruce video it tells miliF, what is the voltage rating of the capacitors?
thanks
rsequeira is offline Find More Posts by rsequeira
Old Mar 20, 2014, 08:42 AM
barok's Avatar
Canada, ON, Toronto
Joined Apr 2006
me build..
sudscribe..
barok is offline Find More Posts by barok
Old Mar 20, 2014, 08:51 AM
Joined Jul 2005
The capicators are .1 microfarad or 100 nanofarad. The voltage rating isn't critical, and 16v or greater will work fine.
Old Mar 20, 2014, 09:57 AM
Punching holes in clouds
MatZeRO's Avatar
UK
Joined Aug 2010
I watched the video from Bruce and thought it was a great idea.
We had a quick play today to see if we could knock up something following his guide. We just added some headers to make it neat. I think we will end up shrink wrapping it to keep it all clean.
Bit of mess on the bottom but it works fine.
MatZeRO is offline Find More Posts by MatZeRO
Old Mar 20, 2014, 10:39 AM
Israel
Joined Mar 2012
wow nice build MatZeRO! I like the headers there. Make it easy to plug and play.
resqueria, as mentioned above, the capacitor is 0.10 uF. Easy to tell - just look for '104' on the cap.
Old Mar 20, 2014, 10:47 AM
Israel
Joined Mar 2012
If there is a demand for it I can make a smaller version of the board.
I kept it so that all the components are on one side and through hole (30x34mm currently). Going 2 sides & SMD can probably reduce the size by ~20-30%.
Old Mar 20, 2014, 12:42 PM
MatZeRO's Avatar
UK
Joined Aug 2010
Made it a bit neater....
Old Mar 20, 2014, 04:06 PM
Israel
Joined Mar 2012
Sweet!
Old Mar 23, 2014, 02:36 AM
Joined Jan 2013
I didn’t like the dead bug style, so i added it to a prototype pcb board. Its about 3x3cm. Attached pictures are of my build. (red black plug = power, black white = video out, other 2 are video inputs)
I haven’t yet added the hysteresis but should be easy enough when i get around to it. Also if needed i can upload better photos (photos were taken with my phone)
Also thanks for the original plans Bruce, awesome stuff
Len02013 is offline Find More Posts by Len02013
Old Mar 23, 2014, 09:09 AM
Israel
Joined Mar 2012
Nice looking build Len02013. Did you test it already? Does it flicker?
I was surprised when Bruce's build tested fine on a breadboard but showed flickering later on.
Old Mar 23, 2014, 08:57 PM
Joined Jan 2013
Umm I've only tested it with one receiver, still waiting on another to arrive. It did occasionally flicker, but I thought that may have been my hand/arm in between the tx / rx or multipath as it was inside, I didn't see the other led flicker on. I can still solder in the resistor/ capacitors for the hysteresis, so at this stage I'm not worried.
When testing, I did notice, sometime when both video inputs were unplugged (so no voltage on rssi) the two led's were half bright. I'm guessing it was really quickly flicking between the two. but mainly it would flick to the orange led when both unplugged.
Also your pcb version looks good
For Sale free with postage scuba divers Robert Pulse Boats (FS/W) 3 Jan 21, 2014 03:36 PM
Video FPV Quadcopter Awesome Crash in River and Scuba Diver Recovery JAB1a FPV Talk 6 Sep 20, 2013 01:41 AM
Link rcmodelreviews Artful Owl FPV Talk 2 Jan 12, 2012 06:49 PM
Discussion RCModelReviews 2.4GHz shootout CrashingDutchman Radios 28 May 08, 2010 09:16 AM
Discussion RCModelReviews.com gives stuff away XJet Product Announcements 0 Dec 15, 2009 01:18 AM
