Old Mar 02, 2014, 10:34 PM
tonyxwing's Avatar
USA, NM, Albuquerque
Joined Mar 2010
Help!
Throttle Servo Suggestion 50cc Gasser
I need a throttle servo for my 50cc gasser I'm putting together. I'm already running all digital on all control surfaces and it's going on a 6v setup with a DLE55. What servo should I put on it?
tonyxwing is offline Find More Posts by tonyxwing
Old Mar 03, 2014, 08:32 AM
WCB
NC
Joined Aug 2005
Any standard analog servo rated for 6 volts will work. I prefer ball bearing servos. Only a few dollars more and well well worth it.
WCB is offline Find More Posts by WCB
Old Mar 03, 2014, 08:43 AM
Mulit-Platform Pilot
barracudahockey's Avatar
United States, FL, Jacksonville
Joined Sep 2004
Yup
barracudahockey is offline Find More Posts by barracudahockey
Old Mar 03, 2014, 11:05 AM
2 Fast 2 Low & 2 Loud
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
Something in the 30-50 inch pound range should be plenty of torque depending upon the linkage set up.
scootrb4 is online now Find More Posts by scootrb4
Old Mar 03, 2014, 02:37 PM
Dana, Indiana
Joined Jan 2007
I run ball bearing digital servos on throttle too, it just doesn't have to be high torque, standard torque is fine. The digitals give better response and more consistent idle setting for my taste.
whitewolf is offline Find More Posts by whitewolf
Old Mar 03, 2014, 08:46 PM
tonyxwing's Avatar
Joined Mar 2010
I have a few Spektrum DS821's lying around gathering dust. Those should work right?
Old Mar 03, 2014, 09:01 PM
WCB
NC
Joined Aug 2005
To be honest with you...I am not impressed with Spektrum servos. A flying buddy had them on a plane and they developed slop in the output shaft very quickly and had to be replaced. It wasn't just one servo...it was several. He might have just got hold of some bad ones, but it was enough to make me avoid them. Others opinions may be better.
Old Mar 03, 2014, 09:28 PM
Dixie Sky Devils AMA# 1015548
tupeloflyer's Avatar
United States, MS, Tupelo
Joined Oct 2012
One of those will be more than enough servo for throttle. will work fine
88 oz-in @ 6v you would have to have major binding for it not to work!
tupeloflyer is offline Find More Posts by tupeloflyer
Old Mar 03, 2014, 09:49 PM
TigreJohn
United States, CA, Corona
Joined Aug 2008
Sometimes it depends on the radio you have. I do know the Airtronics SD-10G radio with its matching 10 channel receiver is digital only. I missed that a put an analog on the throttle on a set-up. If I moved the stick real slow, no problem. But when it was fast, oh-boy! It took the servo about 6 seconds to move full travel and it didn't sound pretty. I guess the problem is the increased resolution on FHSS-3 (2048) versus FHSS-1 (1048) confuses the analog servos.
jjkupinski is online now Find More Posts by jjkupinski
Old Mar 03, 2014, 11:40 PM
tonyxwing's Avatar
Joined Mar 2010
I have a JR 9503. I'm gonna go with that Spektrum I have. Thanks for all your help fellas!!
Old Mar 04, 2014, 08:18 AM
Joined Sep 2004
Look up the warning that Spektrum issued for those servos
Old Mar 04, 2014, 10:27 AM
scootrb4's Avatar
Joined Nov 2011
http://www.rcgroups.com/forums/showthread.php?t=959657
Old Mar 04, 2014, 12:46 PM
Joined Sep 2004
This
•Manufacturer Warning: "Not recommended for planes over 1.20-size or helicopters over .30-size. Loads and vibration in larger models may cause premature failure of the servo, resulting in damage or injury to property and persons."
Old Mar 04, 2014, 08:56 PM
tonyxwing's Avatar
Joined Mar 2010
This
Looks like I'm gonna go with something else for sure.
Old Mar 05, 2014, 07:40 AM
tonyxwing's Avatar
Joined Mar 2010
Going with a Hitec 5645MG servo. It's probably a little overkill but better to be safe than sorry.
Wanted trade AGM 30+$ for 50cc+gasser mark l Aircraft - Fuel - Engines and Accessories (FS/W) 1 Mar 11, 2014 12:57 PM
Sold SBACH 300 87in 50CC GASSER NEW Go4it Aircraft - Fuel - Airplanes (FS/W) 4 Nov 15, 2013 02:57 PM
Question good throttle *servo for 20 cc gasser?? romano_st Engines 11 Oct 30, 2012 08:16 AM
Question Building a 50cc airplane need Rx/Servo power Suggestion iskoos Giant Scale Airplanes 3 Aug 05, 2011 11:10 AM
Sold Quadra 50cc Gasser dizzane Aircraft - Fuel - Engines and Accessories (FS/W) 0 Oct 03, 2006 10:32 PM
