Old Jun 19, 2013, 06:31 AM
Southern Darling Downs Qld, Australia
Joined Sep 2010
ESC Brake.On.damage?
Hi , i have read in one "only one"that leaving the esc brake "on"can damage the esc because the wind is trying to turn the prop while it is being held still by the current from the esc. I only have a 6x4 prop so i cannot imagine this would draw much current.... by the way this is for a parkflyer not a glider with a folding prop...... i like to fly with the brake "on" because it gives me a better glide but i don't want to damage my ESC..... Help
Kennyglide is offline Find More Posts by Kennyglide
Old Jun 19, 2013, 06:49 AM
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
Leaving the brake on will not cause any damage. The braking effect is caused by shorting the motor leads via the ESC when the power is off. I like the brake on too.
whitecrest is offline Find More Posts by whitecrest
Old Jun 19, 2013, 01:13 PM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
With the brake on any current flow comes from the motor, not the ESC. The windmilling propeller makes the motor act as a generator. The ESC will not be damaged.
Larry
Lnagel is offline Find More Posts by Lnagel
Old Jun 19, 2013, 05:36 PM
DX5e fatal flaw- PM me!!!!
United States, NY, Cortland
Joined Sep 2010
To be horrifically clear, the current generated by the motor turning from the wind goes through the turned-on FET transistors on the ESC, and the current is much much less than what the ESC is designed to handle.
CNY_Dave is offline Find More Posts by CNY_Dave
Old Jun 21, 2013, 04:26 AM
Joined Sep 2010
Thanks everyone, i can rest easy now ........also not an easy task finding programming instructions for the red brick 50amp esc ( this is the hobbyking one that is only capable of handling 3s max) Cheers Ken
Question I need a cheap 18 amp (or more) ESC with brake. What's out there? Miami Mike Power Systems 3 Jan 13, 2013 03:55 PM
Discussion ABS braking causes damage? rangamatchstic Off-road Cars 4 Jan 08, 2013 08:22 PM
Question How do I set the brake on an Electrify ESC when throttle is on the switch? robh Power Systems 8 May 23, 2009 09:38 PM
Question ESC.. Brake vs No Brake on brushed motor? bartricky Beginner Training Area (Aircraft-Electric) 3 Mar 16, 2008 10:22 PM
Discussion F5D brake or no brake on esc jaywatay High Performance 5 Dec 12, 2006 02:04 PM
