Old Feb 13, 2013, 08:19 PM
President @ Acadian RC Club
jonathan7x70's Avatar
Lafayette, Louisiana
Joined Dec 2005
Rimfire 50cc 230KV & Turnigy Dlux 160HV ??
Anyone using this set up yet?
Rimfire 50cc 80-75-230
Turnigy Dlux 160HV
I cant get over about 1/4 power showing 30 amps before loud noises that sounds like a timing issue.. Not sure..
The motor runs fine with no prop but with a prop it squeals really loud.
I tried every combination with the Dlux programing card with no luck.
I might have to go with the CC Phonex 160HV.
Any ideas please share and lets talk!
jonathan7x70 is offline Find More Posts by jonathan7x70
Old Feb 14, 2013, 01:20 AM
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
I's first go over all battery to esc to motor connections, one bad one here could cause your current problem. Be sure there is no solder flux, dirt etc in any connection. Clean with a strong solvent like acetone.
Be sure the esc is set for lipo, you will need medium timing at minimum, and the pwm setting may need to be at least 12, default on most units is 8. Lipo cutoff should be at 3.2 per cell.
Thats the best I can offer. Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old Feb 14, 2013, 01:50 AM
Joined Jan 2010
Turnigy Dlux 160HV
What voltage are you using? I'm running similar motor (220kv) on 10S with same ESC with no issues at all. Joe.
jofro is offline Find More Posts by jofro
Old Feb 14, 2013, 12:34 PM
Joined Dec 2005
Clean solder joints.
Not sure what pwm settings are?? Freq up dates? 8 or 16?
I have the Dlux programing card so I can see all the setting easy.
I am using 12S...
With or with out the amp meter it does it... It happens just over 30 amps.. like 1/4 throttle... very loud screeching... not studdering not cutting off.... makes loud screeching..
The ESC stays cool how ever long it runs.. even at 27 amps... cold!... then at that magic amount when it makes the noise... about 30 to 31 amps... the ESC gets very hot instantly like after finishing 3 very hard flights back to back.
I think it has to do with the Motor and ESC not matching up right... If that is possible.
I have been using Turnigy Dlux ESC's in everything for years with NO problems.. until this motor and a Hobby King Motor the G something.
Old Feb 14, 2013, 03:58 PM
Joined Dec 2005
here is a video of what it is doing...
Not the same motor but the same thing... I think its these larger motors.. The Dlux ESC cant handle the timing?
Turnigy Dlux problems (0 min 34 sec)
Old Feb 14, 2013, 05:04 PM
Joined Jan 2010
Try to re-program timing to low and freq. to 8 to see hat it does. I have found that some motor/ESC are not very compatable, but normally would give you sign of it as soon as you apply the stick. Be careful not to overheat that ESC while playing up with it, while ago I burned the complete EDF jet to ashes using Scorpion130 not being compatable with my ARC motor. At the fraction of throttle movement, even before the fan turned the ECS overheated to the point that the model caught fire burning the lot inc. 12S/4000 packs. All there was left was 6' long Delta impression in the grass. See my shots in the Lipo fire Thread, Joe.
Old Feb 14, 2013, 06:35 PM
Joined Dec 2005
I think your right Joe... Some ESC & Motor combos are just not in love with each other.
I use this ESC on Eflite motors no problem... But so far... Rimfire, G series (from HK), and Motrofly Dont like the Turnigy Dlux ESC.
I ordered a CC for this motor!
Old Feb 14, 2013, 08:17 PM
Where the hell is Biggles
Nederland's Avatar
Upstate New York
Joined Mar 2005
I tried running a Rimfire 65 cc on a Turnigy DLUX 160 HV and it was a disaster,,,,
It would just stutter and make noises and I probably almost ruined both.
I bought a CC ,and everything runs flawless !
If you want to run the big stuff, buy the good stuff.
Never a problem with the CC Esc's ,,plus you get the data logging,,,,Priceless!
Nederland is offline Find More Posts by Nederland
Old Feb 14, 2013, 11:09 PM
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
I have a turnigy dlux 160 hooked to a rimfire 50 with zero problems. I didn't even have to mess with programming the esc.
kahloq is offline Find More Posts by kahloq
Old Feb 15, 2013, 08:20 AM
Joined Dec 2005
well the Dlux for me on the 50cc rimfire was horriable... sounded like 1,000 Cats in heat on a full moon + fingernails on a chalk board.
I was reading on the Fourms more.... I found ware some are using the ZTW-B Series with good results and no bad results unlike the Dlux mixed reviews.
I ordered both the Castle and the ZTW-B Series.
Will report on both!
Well we know the CC will work just fine... but at a price! lol
I dont mind paying to play but why toss away a Benjamen Franklin if you dont have to, ya know!! Thats another 6S, 5000mah Battery!
Old Feb 23, 2013, 07:22 PM
Jeff Carr
Ft. Mill SC / Charlotte NC
Joined Mar 2001
In the video are you running 12s? It looks like a 6s battery. It apperars its hitting LVC ( Low Voltage Cutout) This would be normal. I didnt hear the squeeling but thats a timing issue. Try Low first. The PWM should be OK if low doesnt do the trick try High. I think the ESC will work because if there were other issues you wouldnt get what you have in the video.
Jeff
Goinav8n is offline Find More Posts by Goinav8n
Old Mar 07, 2013, 01:27 AM
United States, MA, Arlington
Joined Jun 2012
Jeff
i would agree it looks like a low voltage cutoff
stagger123 is offline Find More Posts by stagger123
Old Mar 08, 2013, 07:34 PM
Joined Dec 2005
Actually if you guys read post #5 it says...
("Not the same motor but the same thing... I think its these larger motors.. The Dlux ESC cant handle the timing?")
I had two different motor, esc, battery, set ups.
1. Motorfly DM-4325-380 @ 6s
1. RimFire 50cc @ 12s
Both motors turns out to be great... it was the lower grade esc that the timing could not match the motor.
I got two ESC's by Castle Creations... 1-100amp & 1-120amp HV.
Both motors run super awesome thanks to trusty Castle Creations ESC's!
Old Mar 09, 2013, 09:37 AM
United States, MN, Elk River
Joined Oct 2011
Amen brother! Castle and Jeti are hard to beat. I am in love with my Turnigy motors, but HK esc's are hit and miss.
Bipesexual is offline Find More Posts by Bipesexual
Off Site Turnigy c6364 230kv flyingcubby Aircraft - Electric - Power Systems (FS/W) 1 Apr 27, 2014 03:36 PM
Sold New Turnigy C6364 230kv foamflyer Aircraft - Electric - Power Systems (FS/W) 1 Dec 13, 2011 05:00 PM
Question Turnigy 6364-230Kv on 8s....but which ESC?!? ryanrcflyer Power Systems 4 Aug 22, 2011 12:59 PM
Wanted Turnigy SK 63-64 230Kv Chuchuf Aircraft - Electric - Power Systems (FS/W) 1 May 03, 2011 07:09 AM
Discussion Sync problem with Turnigy SK 63-64 230kv Shuffle Power Systems 1 Apr 10, 2010 08:45 AM
