Old Apr 16, 2011, 11:40 PM
Joined May 2009
Question
Phoenix Ice Lite 50: What's a red LED indicate?
Hello all,
Hoping someone who is familiar with one can help.
My motor(rimfire.32 aka 42-50-800) calls for a 45amp esc. Using a 4S 5000 lipo. 3 standard digital servos.
So I used the Ice lite 50 since I had it on hand.
When I run the motor up to slightly below 3/4 throttle the led is amber.
But when I add more throttle it turns to red. Is this normal or does the red mean it's on it's way to burning up?
Also, in case it matters, I was testing without a prop.
But in any case, would still like to know what the red led is indicating.
Would appreciate any help.
Thanks.
seair is offline Find More Posts by seair
Old Apr 17, 2011, 03:15 AM
Alameda, CA
Joined Dec 2006
http://www.castlecreations.com/produ...oenix_ice.html
From the Castle site:
Red LED
Blinks out c • ell-counts /error codes
• Flashes a little at low throttle
• Flashes a lot at high throttle
• Solid on at full-throttle
• Pulses quickly when governor-mode is locked
Yellow LED - used for Data Logging (Phoenix Ice, Phoenix Ice Lite
and Phoenix Ice HV only)
• Yellow LED flashes when logging, and is on continuously
when log is full.
So, I'm guessing what you percieve as amber is the red led flashing. Otherwise, sounds like things are working as they should - GO FLY!!
Hope this helps.
Steve
sgomes is offline Find More Posts by sgomes
Old Apr 17, 2011, 09:04 AM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
As Steve says... solid red indicates full throttle.
Don't test run for extended periods (>15 seconds) with no prop!
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Apr 17, 2011, 11:30 AM
Joined May 2009
Red LED
Blinks out c ell-counts /error codes
when log is full.
Hope this helps.
Steve
By amber, I meant yellow. It blinks red way before(just over 3/4 throttle) full throttle.
Appreciate the link, but have already checked it. Many times. I haven't found anything stating what the led colors indicate though.
Thanks anyway.
Old Apr 17, 2011, 12:10 PM
Alameda, CA
Joined Dec 2006
Uhhh, reread my post, which I got directly from the Castle site, which you "...have already checked.."......."Many times."
Steve
Old Apr 17, 2011, 12:24 PM
USA, NV, Caliente
Joined Mar 2009
What happens if you do? I had no idea that was a no no.
crypto666 is offline Find More Posts by crypto666
Old Apr 17, 2011, 12:42 PM
Dr Kiwi's Avatar
Joined May 2003
A considerable amount of heat .....and no cooling air flow.
Old Apr 18, 2011, 11:02 AM
Joined May 2009
Sorry Steve. Understand now what you wrote.
Guess I should have read it one more time.
Thanks and cheers!
Sold Castle Creations Phoenix ICE Lite 50 gliders Aircraft - Electric - Power Systems (FS/W) 1 Apr 07, 2011 03:09 PM
Discussion Need a consensus on Phoenix Ice Lite 50 for lower amp motors. kevinO Castle Creations 0 Mar 28, 2011 03:41 PM
Sold Castle Phoenix ICE LITE 75 ESC $ 55.00 griffin 27 Aircraft - Electric - Power Systems (FS/W) 2 Mar 13, 2011 09:40 PM
Sold Castle Creations Ice Lite 50 killermolly Aircraft - Electric - Power Systems (FS/W) 4 Mar 12, 2011 05:23 PM
Sold Castle Creations Ice Lite 50 killermolly Aircraft - Electric - Helis (FS/W) 0 Mar 11, 2011 10:24 PM
