Old Jun 20, 2003, 03:19 PM
Boston, MA
Joined Dec 2001
pic pro question
Hello,
I'm thinking of getting a pic pro and wanted to know what essential mods were needed. I know that a main shaft retainer is a must. I've also heard that an aluminum hub is nice also. Does the swash need the ball mod on the pic pro? Also, I'll be using a model motors 12/15/20. Which pinion would you recommend? Thanks,
Will
wsilvio is offline Find More Posts by wsilvio
Old Jun 20, 2003, 08:54 PM
United States, FL, West Palm Beach
Joined Jun 2001
Hello
Aluminum Head(or stiffen the current one)
Aluminum Hub
GWS 7.2 volt grey end bell motor for tail with 10 tooth pinion
8 tooth pinion for you motor with 3 Etech 1200 lithim polys
Shaft collar
From there just make sure your bearing is glued onto the outer and inner portions of the swash and you are set.
All I can say is use good equipment for this heli and it will fly extreamly well.
If I had to do it again from scratch I would get exactily what I said above and the following electronics:
Newest Phionex 10 controller
Schulze Slim 105He
Hacker B20-18L(but you already have a motor)
HS55 for the pitch
2x HS50 for the cyclic
Futaba GY240
The key is light and lots of HS and you will have lots of fun. I think you will really like the Pro.
Happy Flying
Carlo
Eco8gator is offline Find More Posts by Eco8gator
Old Jun 20, 2003, 09:15 PM
Boston, MA
Joined Dec 2001
Carlo,
thanks for all the info. I'm going to use hs-50's a gy240, the modelmotors 12/15/20, phoenix 10(newest software) and 3 e-tec li-poly 1200's
Old Jun 20, 2003, 09:31 PM
Boston, MA
Joined Dec 2001
Carlo, one other question. If I get an aluminum head from PMP products, which aluminum hub works with it. It their ad, it sounds like it only works with the stock head.
Old Jun 20, 2003, 10:03 PM
Joined Jun 2001
Hello
The aluminum one that Warren sells will work. All you have to do is install the screws with some locktight, and sand the heads off. Just make sure that you thread the screw to fill the tapped hole in the hub, and also have enough screw so that the hole in the beaings are filled. This mod is very easy to do. JUST make sure that when a crash is about to happen, turn the throttle off(I like to use my throttle hold switch).
Just so you know I am using the metal hub with the PMP head.
Oh, and one more thing you may want to add a little dampening to the PMP head if you get it. All it takes is a thin sheet of rubber under the head cap. Just do a search and you will find this mod.
Carlo
Old Jun 20, 2003, 10:19 PM
Boston, MA
Joined Dec 2001
Thanks Carlo.
Old Jun 20, 2003, 10:27 PM
Joined Jun 2001
No Problem.
Keep us posted on your progress.
Carlo
Old Jun 21, 2003, 03:12 PM
Boston, MA
Joined Dec 2001
Carlo,
Any advice on the phoenix 10. Are you using high or low governor mode, and what kind of throttle curve. I don't think I need super rediculious head speed since i'm not ready for wild 3d yet. I was thinking around 2000rpm might be good.
Old Jun 21, 2003, 03:42 PM
Joined Jun 2001
Hello
Im not using the Phionex 10, I am using the Schulze 18He.
Use the Low governor mode with the medium timing setting.
I have found that my tail's holding is greatly improved when in governor mode.
Carlo
Old Jun 21, 2003, 03:47 PM
Boston, MA
Joined Dec 2001
Great. Probable going to order everything on Monday. Can't wait.
will
Old Jun 21, 2003, 05:38 PM
Boston, MA
Joined Dec 2001
Hey Carlo, if I use the tail motor you mentioned, is the gws 2 amp esc big enough or should I get a pixie 7. I can's afford a 70.00 high freq. tail esc right now. Aluminum head seems more important.
Old Jun 21, 2003, 06:06 PM
Joined Jun 2001
Hello
I would get a bigger ESC for the tail like a 5 amp GWS or the Pixie. The Schulze Slim 105 He is a little more than the Pixie (50 bucks shipped from Icare) and it is well worth the money. Its simply the best.
http://www2.jonction.net/~icare/motor-controls.htm
Carlo
Old Jun 22, 2003, 12:12 PM
Boston, MA
Joined Dec 2001
Sounds good. Better to pay a little more now than buy twice!
Old Jun 22, 2003, 01:45 PM
Boston, MA
Joined Dec 2001
Alright so I went and did it. I ordered everything for my Pic Pro. I got the schulze controller, the aluminum head and hub, also went ahead and got a PMP one-way hub and frame stiffener. Also got the tail motor you talked about with 10 tooth pinion. This thing should be sweet. Thanks for all your help Carlo. I'll keep you posted on the progress and post some pics.
Will
Old Jun 22, 2003, 07:52 PM
Joined Jun 2001
Sounds like you are about to have a lot of fun. Ill keep an eye on this post.
Carlo
Pic pro on g10 frame question wsilvio Micro Helis 7 Dec 09, 2003 08:42 AM
Pic pro with edf question wsilvio Micro Helis 4 Nov 24, 2003 07:55 AM
Pic-Pro controls question, channel count Earthbound Micro Helis 2 Nov 04, 2003 06:54 PM
pic pro brushless setup question erict Micro Helis 1 Sep 29, 2003 12:35 PM
Yippee! E-Glider Pro question! helihawks Thermal 1 Mar 08, 2002 02:41 PM
