Closed Thread
Old May 20, 2010, 12:30 PM
Chuck 'Em and Chase 'Em
Fly2High's Avatar
United States, NY, Plainview
Joined Aug 2005
2.4 install best practices for a 2 antenna Receiver?
Guys,
I was wondering if there are any best practices for a two antenna receiver installation. Many of the manufacturers offer two antenna receivers as do some of the module manufacturers.
Futaba does not suggest orientation in the 6008/6014 and Spektrum/Jr offers some thoughts. I am looking into Hitec and Airtronics and will update.
Should it always be left and right side out at a 45 degree angle?
Is it better to have one in the nose adn the other vertical out top or bottom?
What works best vs. what is recommended?
I figure this might be helpful for any newbees to 2.4 and istallation in a DLG.
I know what some of the manufacturers recommend but has this been proven to work best in practice?
thanks
Frank
Fly2High is offline Find More Posts by Fly2High
Old May 20, 2010, 12:58 PM
Fly R/C writer
Redlands, Ca
Joined Dec 2004
Hi Frank,
It kind of depends on the rx you use. I have mine equipped with the AR500 rx, which has one long antenna and one short one. I placed the long one out the left side of the fuselage about halfway down the side at the mid-point of the wing saddle. The short one is sticking out on the right side about halfway down in the nose. This has been a reliable set up for me.
For some other ideas on antenna installs, check out The 2-Point-4 Chronicles at my web-site, http://mysite.verizon.net/respri94
Here you will read about the testing and research we performed to debunk some of the myths and hearsay on 2.4Mhz use. We find out about things that are not supposed to work, but do, and things that are supposed to work, but don't. Myths are busted and practical application is explored. It's all commercial free, no fees or cost to you, and heck, I don't even want to know your email! Just download and enjoy.
Thanks!
Mike Lee
mlee8249 is online now Find More Posts by mlee8249
Old May 20, 2010, 01:01 PM
a.k.a. Matt Nelson
MattN's Avatar
North Tustin, CA
Joined Oct 2008
There have been two threads recently on this topic. One started by G_T and an earlier one started by me.
-m@
MattN is online now Find More Posts by MattN
Old May 20, 2010, 01:44 PM
Fly2High's Avatar
Joined Aug 2005
No prob. I'll close it.
I did not know that.
Closed Thread
Question New recruit to 2.4, antenna orientation? GregG High Performance 32 Apr 23, 2010 05:56 PM
Discussion best RX connector orientation for a Dynam E-Razor 450 and others hamburger Mini Helis 1 Apr 17, 2010 11:19 AM
Discussion help.2,4 GHZ Video Transmitter Antenna Orientation fpvbird FPV Talk 17 Oct 04, 2009 01:48 PM
Discussion RX TX antenna orientation and type for high altitude above field Matt Gunn FPV Talk 4 Sep 09, 2009 03:18 AM
Discussion Correct/Best 2.4Ghz Tx Antenna Orientation gregw Radios 6 Jun 20, 2007 07:55 AM
