Old Mar 22, 2010, 02:21 PM
Bristol, UK
Joined Mar 2010
Have I made the wrong decision??
Hi all,
Hoping someone can shed some light on the JP Buebird elec glider I have just bought. Having got it, I then found this video on youtube:
RC BLUEBIRD GLIDER tip stall (me novice) (1 min 0 sec)
where someone says that it is a 'dog' to fly. From my first impression it seems as though it may be tail heavy and that some washout may be necessary, but I think I need more people on the case to work out I have made a bad choice
Many thanks guys,
C
Cerberus256 is offline Find More Posts by Cerberus256
Old Mar 22, 2010, 02:42 PM
flyboy320's Avatar
Canada, ON, Burlington
Joined Sep 2004
I don't know anything about this glider, but it looks like from the video he was flying it too slow and it tip stalled (looks like several times). I've seen real planes fly like this (tip stall into the ground), so it may not be representative of the plane itself, but more of the pilots ability to fly it correctly. Or it could be as you say, an incorrect CG.
flyboy320 is offline Find More Posts by flyboy320
Old Mar 22, 2010, 02:57 PM
Bristol, UK
Joined Mar 2010
Ok, thanks that regains some faith. Is tip stalling something that can exaggerated by high aspect ratio design when entering into a tight turn? i.e. is this something that could be inherrent in high AR wings that would require a certain flying style? I am moving into sailplanes from regular electric so any advice would go a long way
C
Old Mar 22, 2010, 03:36 PM
LSF303 / AMA Life Member
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
From the video it looks like he was trying to climb it on the prop rather than on the wing ... a moderately powered plane needs airspeed to climb rather than just pointing the nose up and climbing out.
Also, he did appear to be flying far too slowly.
Finally, if it's easy to do, just twist a little washout into the wing and hit the mylar with a heat gun to help the tip stall.
I don't think it's a waste, you just need to fly it as it was designed.
Start with a forward CG and some airspeed, it will fly. Once you get it working, you can start moving the CG back and tweaking your setup.
Too much control travel on the V-tails can also be a problem, flight speed is your friend.
Best of luck ...
tk
tkallev is offline Find More Posts by tkallev
Old Mar 22, 2010, 10:20 PM
Culper Junior
eastern pa
Joined Feb 2007
Two words-pilot error
aeronca52 is offline Find More Posts by aeronca52
Old Mar 23, 2010, 12:07 AM
September 2010
Outback Joe's Avatar
United States, OR, Lakeview
Joined Oct 2009
In the video the pilot is way behind the airplane and it is being over controlled all the way. The plane looks like it wants to fly if it is handled correctly as others have pointed out. I don't think that you have made a mistake, just fly the plane like it is designed.
Outback Joe is offline Find More Posts by Outback Joe
Old Mar 23, 2010, 09:34 AM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
What they said. Incompetent pilot.
..a
Old Mar 24, 2010, 06:20 AM
Bristol, UK
Joined Mar 2010
Thanks all, faith restored. I'll get started on the build soon and will try to post my progress, just need to wait for my brushless etc. to arrive now Thanks for all the advice, much appreciated.
C
Old Mar 29, 2010, 10:39 AM
320pilot's Avatar
Joined Mar 2009
watched the video twice. Looks underpowered, CofG could be back a bit. How much down elevator did it take to get the nose down? How did it fly hands off?
He really doesn't have any speed at all , when he flies it into the 60 degree banked turns. First thing you do, making a steep turn like that (with underpowered plane) is push the nose down, or stick to shallow bank angle. Maybe programing in some Expo would help, for shallow turns, rather than just holding the stick over.
I think a bit more nose down trim (CofG?), and more powerful motor setup would help.
Still, sad to see a crash on a maiden flight..
my 2c worth
320pilot is offline Find More Posts by 320pilot
Help! I have to be doing something wrong here BEELZEBOB Scratchbuilt Indoor and Micro Models 3 Mar 10, 2010 08:45 AM
Build Log OK, I finally made my decision and I picked the Eva Bipe........... mtdoramike Parkflyers 12 Nov 29, 2009 01:50 PM
The Decision is Made... I think. Opinions Drunken_Rockstar Electric Plane Talk 4 Jun 21, 2004 09:43 AM
Help! I made a dumb decision so now I.... DICKEYBIRD Batteries and Chargers 12 Oct 21, 2002 12:49 PM
I made my Camera Plane decision: eBird Parkflyers 9 Sep 01, 2002 11:26 AM
